Question about IBM ThinkCenter M50 (8189A1UJ) PC Desktop
On my ibm mt m8187 as soon as I plug it in it pwers up without pressing the switch. The fan and hd light comes on then off but fan keeps running with no boot
Won't boot to cd either
  • 1,162 Answers
Have you changed something. It sounds like you have lost your config files. With out proper software or boot disk you will need help
Posted on Mar 30, 2014
5 Suggested Answers
tech4allmen
  • 666 Answers
SOURCE: looking for IBM thinkcenter M8187
I work for IBM and i'm so lucky to find this concern of yours. You have posted a very detailed information about your computer. In return, here is the link for the drivers of your Thinkcenter M50 computer. In this website, you will find all of the drivers, applications, and software you need for your system. Please CLICK HERE.
Thank you for visiting FixYa!
Posted on May 09, 2011
  • 166 Answers
SOURCE: IBM ThinkCentre 8183 (M51) does not boot
The situation you describe is usually 1 of 2 things, Power supply (PSU) or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup. Fans are usually the first thing to get power, then the mobo for the Power on Self Test (POST).
Situation #2: You might get some power lights coming on and some fans spinning but the video output does not happen and normal startup sounds do not take place, usually indicates that motherboard is going out or has gone out. OR it may be due to a weak (damaged) PSU.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Since you have tried removing components then it looks like you have narrowed it down to either the power supply or motherboard. If your motherboard looks ok and if you can get another power supply that has an output watts that is greater or equal to the one that you have, try replacing that first.
Posted on Apr 14, 2009
vipin_yadav1
  • 80 Answers
SOURCE: IBM THINKCENTRE A51 - WON'T BOOT
Simple dear, I think that you can see the power led and hdd led but it wont boot. Right. So switch the system and than open the cabinet and than remove the RAM , CLEAR THE DUST ON THE SLOT AND RAM. THAN REPLUG IT IN THE SAME WAY. PLEASE DO NOT INSERT IT FORCEFULLY BECAUSE IT WILL GO EASILY IF YOU ARE INSERTING IT IN RIGHT WAY. SO CHECK THE POSITON OF THE NOTCH ON BOTH THE RAM AND SLOT OK
AND THAN START THE SYSTEM. THIS MIGHT DEFINATELY SOLVE YOUR PROBLEM.
Posted on Nov 19, 2008
prince07
  • 79 Answers
SOURCE: IBM 8183 , when i
i think your server got low contact heat sink so reinsert your heat sink with thermal paste..but u must check your power switch if functioning perfectly first.
Posted on Sep 03, 2011
Computer won't come on when pressing power button
Disconnect the desktop computer from the electrical power.
Plug it in, while looking at the computer, and listening for any noises (spinning fans, or lamps that light up) as soon as it is plugged in. Then, press the ON/OFF switch, and watch any lamps, and listen for any fans. If nothing, then the power-supply is the problem.
Aug 21, 2015 | Computers & Internet
I have an IBM x3400 MT 7975 server that is failing to power up. When i connect the power cable the green LED comes on but when i press the power button the fans run for about 1 second and turn off and the...
Hi
Welcome to fixya
Sounds like the Power cage has the fault .Probably this case would arise if the power cage gets fault This reason is the server is not getting the proper power to start . Probably this case would arise if the power cage gets fault.
Please replace the power cage and this will solves the problem
Thanks
Jan 13, 2011 | IBM x3400 Server
Persario will not power up with switch, I unplug the power cord from the wall. wait about 5 mins, then plug the power cord back into the wall. the computer powers up without the power switch then shuts off...
IS THAT A Relic CRT monitors/?? wow.
NOW THE FULL STORY. (GOT TIME NOW, IM IN MEX,GULF ON A BOAT,WITH SLOW WIFI OR NEAR DEAD.)
the PSU is dead if the power button acts dead
no fans right ? no sounds, the 2 or 3 fans do not spin and blow
1: bad PSU
2: or objects plugged into the mobo are shorted,
3: mobo dead (Motherboard)
do the jump test?
here
http://www.pcdied.com/power.html#Jumper
Jan 24, 2018 | Compaq Presario 4410US (470027-053) PC...
Ford focus 1.6 52 reg radiator fan comes on as soon as car is started from cold? is this normal
no the fan shouldent check that you ac is off as the fan comes on with the ac you can check the ford fault codes without going to a maindealer follow the instructions i am giving you
press the trip button and hold while turning the key starting the engine keep the tripbutton pressed for about 10 seconds then release the next time you press it it will do a sweep test of all gauges and dash lights the next time you press it it will then give differant bits of information flow rates oil flow and any fault codes
Mar 19, 2010 | 2000 Ford Focus
It dose not runs the hd only power light
If the power light comes on and nothing else works, it could very well be a motherboard problem.
I would suspect this if the hard drive does not start, the fan does not start, and you get no display.
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
Sytem wont boot
This time your system is very ok... theres a possible reason why its automatically on without pressing the button and cannot see a device even hard disk...
Here is a tip:
1. Check the CMOS Battery maybe its weak, or try to change it a new one, and
2. Change also your power supply it might the current flow of electricity are not normal... i know its ridiculous but i experience just like yours...
Jun 20, 2009 | Intel Pentium 4 2.8Ghz System PC Desktop
E Machine T2682 powers up but, doesn't work
This sounds like an overheating problem, that is why the fan comes on right away. When you let it rest, it cools off, and works normally for a while.
Most modern PC's are designed to slow down their operating
frequency when they over-heat, and if that is not enough they
will go into suspend, hibernation or (totally off) modes to protect themselves from permanent damage.
Solutions:
Bigger power supply, more and better cooling fans, improved space and airflow around the cabinet, cool the room with aircond.
also better heat-sinks on the CPU and/or the chip-sets.
all relatively inexpensive.
Apr 17, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
29 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
