Question about Hitachi PJTX100 Multimedia Projector
Optima Optima hd81 projector mounted on ceiling now picture is upside down
    Novelist:
  • 86 Answers
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
Posted on Apr 09, 2014
informatica
  • 1114 Answers
SOURCE: upside down picture
Use the mirror function from the menu as per the picture below choose V:INVERT. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 25, 2007
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Posted on Feb 03, 2008
i have a vpl-vw10ht projector and iv put it to ceiling but the picture is upside down what do i do
Posted on Feb 19, 2008
catnip20
  • 11 Answers
SOURCE: Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
  • 23 Answers
SOURCE: Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Posted on Feb 13, 2009
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
I have a optima projector. When I hook it up to the laptop with windows Vista the image is upside down. When I use the laptop with windows xp everything works fine, The setting on the projector is set...
Hmmmm... You sure should have an option in your Control Panel for that settings. Try exploring your "Screen Resolution" by right clinking on the Desktop, and clicking "Screen Resolution". There'll be options for "Detect" and "Identify". When you connect your Projector, try the "Detect" option and see if a new Display is detected. If there is, click on it and look for "Advanced Settings" and try to find the option for "Invert" or "Mirror" display or something like that.
Or the easier option is to mount your Optima upside down but of course you won't do that as it may be very absurd and funny. (Kidding...
Jun 08, 2011 | Sony VAIO 2GB RAM HD DVDRW Vista Premium...
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
Projector is mounted on the ceiling and display is upside down. how do I fix this?
Go to the setup menu and change the orientation. You will have a number of choices. ex. Ceiling front, ceiling rear. Select the position that the projector is mounted and the picture will reorient and display correctly.
Aug 25, 2010 | NEC MultiSync LT280 LCD Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Sep 28, 2009 | NEC VT465 Multimedia Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Upside down picture
YOU most likely have the thing mounted upside down that all
just flip and check the instructions
>if it is hooked up through a pc you will have to change the settings in on the pc( graphfic/diplay) ROTATE 90degress
PLEASE be kind if i helped and post more if you need help RATE this userKindofcheap
Aug 31, 2008 | NEC VT465 Multimedia Projector
Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
Hitachi PJTX100 Multimedia Projector Logo
142 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
