Question about Plantronics Radio Communications
Echo Windows 7
Echo in earphones when speaking
  • 4 Answers
Turn down volume / input. If unsolved, then uncheck
"listen to this device" under audio input. On Win7:
R-Click on Speaker in taskbar, click 'Recording devices'
& select earphone properties.
Posted on Apr 01, 2014
MaxiTech
  • 15 Answers
SOURCE: H700 Echo Problem.
Each party needs to keep their earpiece (listening) volume at the minimum level that is audible to reduce chance of feedback. Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Posted on Aug 31, 2007
SOURCE: echo
ME TOO
Posted on Dec 26, 2007
  • 4 Answers
SOURCE: echo when using HS850
It might be a problem with their sound setting. If their speakers are on while using the mic, they might get some feedback that could be the cause of the echo. They may even just have to tweak their mic settings (through the control panel sound options or their soundcard options).
Posted on Jan 07, 2008
Nomodo4u
  • 863 Answers
SOURCE: person I am speaking to complains that they can
Go to your phone carrier and exchange the phone out to one that doesn't have echo.
Posted on Jan 31, 2010
  • 72 Answers
SOURCE: When I speak there is
If this suddenly just happened, take the battery cap off from the head piece. Detach the battery and wait 5 seconds, re-attached the battery and you should be good to go.
If this is your first time setting up, there's a round dial on the left side that you have to adjust. Keep the phone on with the dial tone and try different settings on the round dial. There should be a setting that'll give you a clear tone.
Posted on Mar 01, 2011
Testimonial: "Ya it was the dial on the side of the base unit "
Need echo dot app with setup instructions
hi Gary.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
if this does not help you out go to this link and read up some more.
echo dot app with setup instructions Google Search
Nov 20, 2017 | Echo Computers & Internet
Setting up echo dot
hi roger.
see if this helps you out.
or if you need more help go to this link.
Setting up echo dot Google Search
Nov 16, 2017 | Echo Computers & Internet
How do I fix error 0X80070005 ? It sure blocks everything I download. This Acer Aspire E15 was bought on the 3rd of December 2014 & we are today 3rd Jan 2015 ! Gets me to wonder as I only down
  1. Download the SubInACL tool and install it in the %windir%\system32 folder. The %windir% placeholder represents the Windows operating system folder. For example, C:\Windows.
  2. Start Notepad, and then copy and paste the following commands:
    @echo off
    subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f /grant=system=f
    subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f /grant=system=f
    subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f /grant=system=f
    subinacl /subdirectories %windir% /grant=administrators=f /grant=system=f
    @Echo =========================
    @Echo Finished.
    @pause
  3. Save the file as Reset.cmd.
  4. Right-click the Reset.cmd file in File Explorer (in Windows 8.1 and Windows 8) or Windows Explorer (in Windows 7 and Windows Vista), and then click Run as administrator. In Windows XP, double-click the file in Windows Explorer.
  5. Wait until the execution finishes, and then try to install the update again.
Jan 02, 2015 | Acer Computers & Internet
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
Apr 02, 2014 | Philips SHM1900 Headset
My ZTE cdma1X modem is not working on windows 7.
Apparently, one of the Windows updates is causing corruption of the Access Control List (ACL's) in the registry. I had entire sections of my registry nodes that lost the ACL'S.
While I was researching the problem, I came across a website where someone had a similar problem with getting windows OS programs/services to run and they discovered that there was some registry corruption and missing ACL's.
There are two different options that I ended up doing to get the system back in operation.
It seems that running one or the other alone will not fix the problem, but doing both should get you back in service.
  1. Make a backup of your registry (and a complete backup of the system wouldn't hurt either!)
  2. Go to Microsoft's website and download a program called subinacl.exe from this site; http://www.microsoft.com/downloads/details.aspx?FamilyID=e8ba3e56-d8fe-4a91-93cf-ed6985e3927b&displaylang=en
  3. Install the subinacl.exe (it downloads as an MSI file).
  4. Copy the code below into a text file and then name the text file reset.cmd.
  5. I copied the command file to my temp folder to run, but as you can see from the cmd file, it contains the path to the executable subinacl.exe.
@echo off
title Resetting ACLs...
cd /d "%ProgramFiles%\Windows Resource Kits\Tools"
echo.
echo Resetting ACLs...
echo (this may take several minutes to complete)
echo.
echo ==========================================================================
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo System Drive...
subinacl /subdirectories %SystemDrive% /grant=administrators=f /grant=system=f
echo.
echo.
echo Windows Directory...
subinacl /subdirectories %windir%\*.* /grant=administrators=f /grant=system=f
echo.
echo.
echo.
echo FINISHED.
echo.
echo Press any key to exit . . .
pause >NUL
3. As this command file runs it will show you the status of the reset and create a log that you can go back into and inspect for problems.
4. When this command file completes, you then need to open a command window (using Run As Administrator) and run the following command;
secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose >c:\temp\secedit_output.txt (the redirect of output echos the programs output to a text file, but secedit also creates a log file. The program will show you the location of the log file when it is done).
These two actions combined will reset the permissions on the registry nodes back to their default settings.
Reboot and check your Event Log service... at this point it should be running.
After effects of this process which happened to me, were that the Network List Service would not run... I still had network and internet access, however the Network icon in the task notification area had a Red X, and mouse over displayed a tooltip that said "Server Execution Failed". This was a result of resetting the ACL's.
The Network List Service (netprofm) would not run because it did not have permission to run.
In order to correct this issue, you must open the Component Services snap-in and drill down under Computers/My Computer/DCOM Config/netprofm (this is for Vista!) and right click the node, and select Properties.
Click on the Security tab and make certain the correct user names are listed and that they have the appropriate permissions. I have 4 users listed with the same permissions; (your mileage may vary )
  1. Administrators - Perms; Local Launch, Local activation
  2. Interactive
  3. Local Service
  4. System
Next, go to the Identity tab and ensure that The System account (services only) is the item that is checked. Make sure the changes you make get applied.
Restart your computer so the ACL's are refreshed.
Once you come back up from the reboot, things should be pretty much back to normal.
You may find a stray program here and there that may need to have it's permissions reset, but you should be operational.
Mar 19, 2010 | Microsoft Windows Vista Ultimate Edition
Help
does it have like a sag-up like sound?? If so, then you need stop using it for a while. Stay away from things that emit strong waves. OR, the reason why you hear an echo is, your earphones might not be compatible with the player!
Jun 20, 2009 | Coby MP-C7085 MP3 Player
Echo in phone when I speak.
U see echoing isnt d problm f the phone... It`s the pbm of d service providers (yr network)....dnt worry they usually get repaired when the correspondn frequencies are altered.....
many others had the same pbm and belive me they got it rite after sometime....
May 22, 2009 | Motorola Mobility L6 Cellular Phone
Hp g6000 running very slow any suggestions.
The HP g6000 slow issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the solution http://www.speeduphp.com/fix-slow-hp.html to give a free & full scan of your slow HP PC to find & fix all possible issues.
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance.
Mar 09, 2009 | HP Pavilion dv6000z Notebook
ECHO effect on my COBY MPC7095
I had the same probleme before, try getting new earphones like I did.
Feb 21, 2008 | Coby MP-C7097 MP3 Player
Radio Communications Logo
70 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
