Question about Panasonic Lumix DMC-FZ18 Digital Camera
Error message This 6yr old camera repeatedly gives me "Please turn camera off and then on". I have "reset" menu but that does not help. Can you advise who would fix this and what it might cost? Thanks Dave
  • Official Brand Answer
  • 350 Answers
Please then use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Posted on Apr 03, 2014
JoeO700
  • 80 Answers
SOURCE: Problem - Turn off and turn on again - happens repeatedly
We see this camera often because the lens gets compressed some how and the plastic gears which drive it become damaged, this would be the "buzzing" noise you're hearing during power up. The camera is not passing its power up diagnostics and therefore it shuts down. The lens is not cost effective to replace on this camera, parts and labor exceed a replacement units cost. Hope this is some help. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 13, 2007
SOURCE: Dropped the camera, shutter won't closed, focus keep moving in and out, message "please turn off camera and turn on again"
This recently happened to me and I too got a hefty quote from the company since mine was no longer under warranty. I figured since it was trash anyways, I might as well take it apart and see if I could figure out what was broken. After removing all of the screws and removing the top pin strip from the board (there is a piece of tape on it) and flipping the lens part away from the board, I was able to remove the small gear compartment on the side of the lens housing (held on by one small screw) and the 3 screws on the back of the lens and carefully flip out the digital camera part and push the lens back into it's original closed position. I then carefully reinserted the digital part back into the lens making sure everything was nice and flush and closed it back up. Works like new :D However, if you're nervous about digital machines, I wouldn't reccomend doing this. Luckily for me when my camera fell it simply knocked the digital lens out from the housing and it didn't pop back in right afterwards, causing the lens to not be able to turn completely like it should. If yours is damaged more than this, it may not be such an easy fix. And the camera is difficult to handle as it is connected by those pin strips everywhere. It made me nervous to handle it as I probably could have made it worse, but, I had nothing to lose. Hope this helps out the next person.
Posted on Aug 20, 2007
SOURCE: Lumix TZ3 keeps giving the same error message: "Please turn camera off and then on again"
sorry to tell you guys this but you definetly have lens faults, for you firwol i can say that you have a focus lens or image stabilizer fault, bob80 sand can definetly mess your lens around and is going to need a service. you can check the error codes. you need to do exactly what i say. turn camera off, mode switch to red camera selection, this has to be done quick, turn camera on holding the ois+ arrow up button, then quickly hold ois+menu+arrow left. post the error then i will tell you what is wrong.
Posted on Jun 26, 2008
SOURCE: Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Posted on Aug 26, 2008
bobint17
  • 270 Answers
SOURCE: please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Posted on Feb 03, 2009
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Turn on but not working
Most all cameras have a "FORMAT" mode that is accessable through your MENU options. Find It and try RE FORMATING YOUR CAMERA. You may lose stored images but it will reset the Camera back to Factory settings. Good Luck
Oct 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Nikon d80 shows err message. still after full reset it wont work
Check if your battery is charged. Are there any error messages? Otherwise, if your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Sep 17, 2009 | Nikon D80 Digital Camera with 18-135mm...
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Please turn camera off & then on again
Feb 03, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Jun 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
System Error (-1) in my 6670
well, i have , all i do just erasing all the logs, and its back to normal again
Mar 25, 2008 | Nokia 6670 Handheld
well well well a simple way to fix it if u r scraed to whack thn tap the lens,menu part ,sides wid a pensil or a pen...bit little harder atlest d cam should get little vibrations well it really works...belive even i had d same problem just after 15days just d previos day to a holiday...thn i just tapped itwid ma fingure n u wont belive it worked...
Feb 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Panasonic Lumix DMC-FZ18 Digital Camera Logo
43 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
