Question about HP DeskJet 6988 Printer
Color printing HP printer not printing in color. Purchased new cartridge and still no luck
    Sergeant:
  • HP Expert
  • 316 Answers
Check your printer preferences and make sure the colour icon is tagged or at least the grayscale option is not tagged. Try holding the power button on and pressing the paper feed button once or three times to generate a self test page. If there is still no colour the cartridge is probably faulty.
Posted on Mar 30, 2014
SOURCE: hp 3745 prints only the red color
my hp 3745 deskjet colour printer printing some time red some time red with black what to do
Posted on Apr 02, 2008
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
Posted on Jun 25, 2008
cariandco
  • 39 Answers
SOURCE: Can I use the printer without a color cartridge.
No, I've never found one. HP wants you to buy those expensive cartridges. However, you can just leave the empty color in place and ignore the message. It will not print at all without a cartridge in it. When you print black, make sure you set it in your printer options to print from the black cartridge only (there are blacks that use some color in them). Or you can get a black only printer. Hope that helps. If so, would you rate this solution? Thanks!
Posted on Oct 13, 2008
wayneard
  • 1901 Answers
SOURCE: hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Posted on Oct 18, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
Color cartridges are full but colored pictures are gross
Use the HP print utility and run through the tests. One bad cartridge will muck up the color completely.
There should be a clean print head option. Run it if the initial color test shows a clog.
Mar 20, 2014 | HP PhotoSmart Office Equipment & Supplies
Printer will not print in color, only black. We just replaced the cartridges.
If its an HP inkjet printer you may have set it to print in black and white. To change this setting go to "control panel", then "printers and devices", right click on your printer, then "printing preferences", "advanced", then uncheck "print in greyscale"......Good luck !
Nov 03, 2012 | HP DeskJet 932c InkJet Printer
My Officejet R80 prints only in red and black; Any suggestions
Color cartridge dried up..Perform clean cartridges through printer properties.. check,,no result, replace color cartridge..
Sep 01, 2012 | HP OfficeJet r40 InkJet Printer
My printer lights ( all three) are blinking with error message of "cartridge problem" I have tried to replace the cartridge with no success and cleaning the cartridge but no luck. Please help.
In this case you will need two new cartridges to identify the problem.
Take one new color cartridge and one black. Now, remove both the old cartridges and install the new ones and restart the printer.
Most probably your issue should be resolved.
Please ensure that you are using the following cartridges only.
Print cartridge information Part name Part description Product number Print cartridge Black HP No. 15 (equivalent to HP C6615 series) Print cartridge Tri-color HP No. 78 (equivalent to C6578 series)
Apr 08, 2011 | HP DeskJet 920c InkJet Printer
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
HP DeskJet 6988 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
