Question about Garden
Honda mower drive cable
Honda HRX475 SXE drive is too slow I have adjusted cable at handle end, this seems to improve things a little.
  • 3 Answers
The drive belt may be worn and slipping on the pulley. (assuming it is a belt driven model). This would cause the mower to lose a great deal of power to the wheels. By adjusting the cable only, you are effectively adding a little more friction to the belt/pulley interface which in turn will provide a bit more power but the belt may still be slipping on the pulley(s) which is where you could still be losing the majority of your mowers self propulsion. Some Honda models may also employ a belt tensioner that simply adds tension to the belt even if the belt becomes stretched out & worn but the pulley's can become glazed (slippery). If it is a direct "pulley to pulley" drive with a single drive belt (no tensioner) the worn belt can also glaze the pulleys and cause further slipping. You can reface your pulley(s) contact surfaces with a very light grade wet sand paper (1000 grit), a coarse grade steel wool or a scotchbrite abrasive pad, thereby giving the belt more "purchase" on the pulley(s) contact surfaces. If you do perform a refacing of the pulley(s), it is strongly advised that you replace the drive belt as well. Your mower will then function as it did when it was new. Hope this helps.
Posted on Apr 05, 2014
  • Rob williams
    Rob williams Apr 05, 2014
    Many thanks for your help Dozer2. In light of your advice I will order and replace the drive belt, and see if that solves the problem .
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
bulldogchief
  • 388 Answers
SOURCE: honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Posted on Sep 08, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
SOURCE: how do I replace the clutch cable on my honda self
I fixed the drive cable just yesterday. If the model is exactly hrx217hxa with the serial number between MAGA–1000001 and 139999 as mine is, it can be quite involved to replace the cable if this is the first time, because honda wants to replace the "control arm" as well. You can find a detailed instruction to replace the drive cable from the following link.
http://www.lawnsite.com/showthread.php?t=281234
The part number that you need to order is 06225-VH7-305, which comes with a very brief instruction on how to replace based on the service manual (not the user manual). The above link will guide you to how to replace the cable, but since the transmission end of the cable changed, you need to replace the "control arm" as well. This requires to disengage the drive "belt", which is the first challenge. Once you disengage it, it is relatively straight forward to replace the "control arm" if you have the right tools (1/8" pin punch and a challen lock plier which are described in the instruction that came with the cable kit).
Engaging the drive belt back on is the biggest challenge in the whole process, unless you have the right tool to handle the powerful spring that pulls the whole transmission to give friction to the drive belt. I spent two hours to try to engage the belt without the right tool (probably you need a "brake spring tool"), and I finally did it.
The rest of the assembly process is straight forward if you memorize what you did for disassembly. The above link can help you as well.
I took pictures of every step, and am going to post it somewhere soon, but if you want to replace it soon, please send me a message if you need help.
Posted on Nov 24, 2009
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
My Honda HRC215 commercial mower goes very slow,how do i adjust it to make it go faster
Is your speed adjuster on the handle working properly? if not there should be a screw holding the cable on the engine Loosen that screw and push or pull to speed the engine then tighten back up.If that don't work there should be a spring coming out the to of the carb and if it speeds up when you push or pull it you can shorten or lengthen that spring. Which ever you need.
Nov 07, 2014 | Garden
Honda hs55 when handle depressed blower fan moves at fast speedauger turns very slow.if auger makes contact with snow auger and blower fan stopsnew belt was installed no slippage of belt present
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
Dec 05, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Changing the drive cable on a honda hrx476 roller mower
Cut or brocke the cable and attach a new one
Sep 28, 2013 | Garden
How to replace drive cable on honda hrb 216 tda
Disconnect both ends, attach new cable. Google model number parts for illustration.
May 08, 2013 | Honda Garden
I have a 2004 Honda VT750 Shadow Aero (shaft drive). Clutch apparently needs adjustment. Nuetral is easy to find but when shifting into 1st or 2nd or any other gear, bike stops. Is this a simple cable...
Adjustment is made at clutch end first and then fine-tuned at the handle bar end. Adjust at clutch end until there is no free play on the lever. Then slack off the nut a quarter turn. Test clutch operation and adjust at the lever end if nescessary. Remember to lock the nuts at the clutch end.
Feb 13, 2011 | Honda VT 750 Shadow Aero Motorcycles
Clutch lever adjustment on 1998 Honda Shadow Aero
Hello After looking at a schematic unless there is an adjuster on the other end of the cable there no adjustment.
Depending on how long that cable has been on there it may be starting to stretch or individual strands and starting to break.
May 25, 2010 | 1998 Honda VT 1100 C3 Shadow Aero
Honda lawn mower wheel drive works, but needs adjustment, how?
Oct 25, 2009 | Garden
Rear end nose 1998 Honda CR-V
have the rear differential and rear axle checked.
Jun 14, 2009 | 1998 Honda CR-V
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
