Question about Polaris Pb4 - 60 Booster Pump
Looking for wiring instructions for the pb4-60 booster pump
  • 1,631 Answers
Check out this link, then scroll down 3 pages:
http://www.electricmotorwarehouse.com/PDF/polaris_manual.pdf
Posted on Mar 17, 2015
    Novelist:
  • 172 Answers
If this is for your polaris booster pump they all have to screws to attach the wires if you have 220 volts it won't matter which wire goes where the longes the pump is rated for 220 volts if you have 120 volts pump is the same just make sure your wires are for 120 volts it won't meter which wire goes on which side just make sure you use L1 AND L2
Posted on Jun 16, 2009
Where can I find a Wiring diagram for hayward super II PUMP AND BOOSTER PUMP to new t106 intermatic and existing t104 for the booster?
Not sure if you will find such a diagram...
New installation?
Do the pumps have their own breaker?
Is your Super II pump a 2 speed?
What is the Thermostat for? Do you have a heater that you are trying to connect, so that the pump will come on when there is a demand for heat? Not really sure what the T-stat is mentioned for here?
You still only need to have 2 timers if I'm not missing something?
The T-106 will be for the Super II pump (presuming it is a 2 speed version) It will turn hi speed, on & off. or switch between them rather. I think I see why you may be inferring about a 3rd timer? You don't want to have pump running on "Low" speed continually. If so, Then you will need a 3rd timer (T-104) to provide power as Line to the T-106. The other T-104 will be for the booster pump for your cleaner.
The power for the Super II pump from the breaker will go to the 1st T-104 as "Line". Then from the Load portion of that timer, you will wire into the Line portion of the T-106. Following the instructions from the diagram at this website address for a PDF document:
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T106R%20Instructions.ashx
you will complete the wiring to the Super II pump via the "Load" side of the T-106
The 2nd T-104 (pool sweep pump) will be wired: from the breaker to the "Line" portion of the timer. From the Load portion of the timer, you wire to the booster pump.
Good Luck
Apr 29, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
Looking for instruction manual for ferrari dreamway booster seat
Try calling Ferrari customer service to ask about the Dreamway booster seat at:781.619.6979
Feb 16, 2013 | Ferrari Dreamway Booster Seat
Wiring instructions to rewire Pentair universal booster pump from 240V(Factory wired) to 120V.
see side of motor for schematic for low voltage you have to move wires or change a switch
Jul 05, 2011 | Pentair 34 HP Pool Pressure Side Booster...
I am looking for a WIRING SCHEMATIC for the Hayward 5060 booster pump MOTOR. A wire came off and I cant find where to replace it.
Please comment with the motor manufacturer and the model and serial number off the motor nameplate. It is likely an AOSmith motor and the info will be somewhere on the motor frame.
John
Aug 25, 2010 | Hayward Pool & Spa
Booster pump cracked
Lock the end of the shaft opposite the pump and then turn of the impeller counter clockwise looking at the pump. The remainder is simple nuts and bolts.
Aug 29, 2009 | Polaris Pb4 - 60 Booster Pump
Looking for wiring instructions for the replacement polaris pump motor. It says it is wired for 240 and I need the configuration for 120. It is polaris booster 3/4 hp pump.
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Apr 24, 2009 | Polaris Pb4 - 60 Booster Pump
Pentair booster pump
First things first. if the drain plug is not in the pump you would see water shooting out of it. Since you said its your first time i must ask if you have the main filter pump on and the booster pump on at the same time, because this is the only way that it will work. Next follow the hose coming out of the top of the booster pump until it goes into the ground, and make sure all valves are open, and then do the same with the hose coming out of the front. If water is coming out of all of the other returns, and just not that one it is probably a valve, but if you have no water going back to any returns, then you have a bigger problem.
Apr 01, 2009 | Pentair Plug, Drain 071131
Polaris Pb4 - 60 Booster Pump Logo
3,189 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
