Question about Breville Fresca BES860 2Cup Coffee Maker
The water flow keeps going whilst making a shot.
When making a shot, the water flow keeps going and does not stop. Not sure what is causing this.
My shower is 6 months old it goes hot and cold whilst on
Newer showers use safety valves to keep people especially children from getting burned they are a single valve with three ports. One ,hot in, cold in, and one port for tub and shower. You need to pull the valve and look for tears in the valve seat.
Mar 27, 2016 | Home
Ice maker won't stop filling. Makes a little ice, but water is almost constant into the maker
The water control valve is shot. It's not making ice because there is a constant flow of water into the ice tray. Shut the water off at the feed point for the fridge for now. If the drain gets plugged you're going to have a small catastrophe on your hands.
Here's a procedure to test it to be sure:
How to Test Fridge Icemaker Water Inlet Valve Refrigerator Repair
Mar 20, 2016 | Kitchen Appliances - Others
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
My barracuda g3 barely goes around the pool and also keeps stopping completly I have taken it to my pool store but they coldn't find anything wrong ith it.
If a store has check the actual pool cleaner for damage and couldn't find any, it is either going to be the connection or the water flow through the cleaner that is causing the lack of motion. Make sure that all of your hoses and connections are tight and secure with no cracks. Air getting into any of the lines could cause problems. You will also want to use your water flow gauge to make sure that you are getting enough water pressure to power the cleaner.
Jul 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have a Hoshizaki Model KM500MAE that keeps freezing up. What can I do to stop this problem
several things cause freeze ups.
If you have water filters on the water system, be sure they are not restricting the water flow. water flow pressure should not go below 20 psi.
The bin stat may not be shutting off the unit properly. It should shut off machine within 10 seconds of ice making contact.
Make sure the float switch is not dirty. Be careful when cleaning. Fragile
Make sure water pump runs the entire time it is in the freeze cycle.
Be sure the evaps are clean. Ice cubes will hang on if not clean.
Water solenoid has a screen where the water line screws on to it. Turn off water and check screen to be sure it is clean. This can restrict water flow.
Make sure water valve closes all the way. Turn machine off and see if water is still running. Valve may be leaking water thru.
Dip switches on the board, #1 and #2. Turn them both on and it will change the defrost time to 3 minutes. If both are off, they are set on 1 minute.
Hope this solves your problem. Let me know
Apr 07, 2010 | Hoshizaki Freezer Commercial Ice Machines...
No heat in cab in ford ranger 2005 tied heater
check if both heater hoses going into firewall are hot.. if only one is hot then your heater core is stopped up..you can take both lines loose and take a water hose and back flush,,, force hose on one inlet of heater core for a minute and then the other.. keep going to you get a good flow...make sure heater valve is open, not just valve position take loose and confirm clear..last make sure your thermostat is not stuck open keeping engine from comming up to temperature
Jan 04, 2010 | 2005 Ford Ranger
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
Espresso does not make
Remove the portafilter and press the brew button, if the water flows from the head with a nice flow then the problem is with the grind (too fine), or the coffee has been Tamp too hard.
If water barely flows when you press the button then try backwashing the machine and removing the shower screen to clean it.
May 19, 2009 | Coffee Makers & Espresso Machines
Timer and possibly more.
yes it an cause the water flow to stop....your best bet is to buy another timer and put in or get another washer.
Jan 21, 2009 | Kenmore 22422 Top Load Washer
Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Breville Fresca BES860 2Cup Coffee Maker Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
