If you're having trouble getting the Toro 360 quad steer to track straight from front to back wheels, there are a few potential issues that could be causing the problem:
- Wheel alignment: If the front and back wheels are not properly aligned, this can cause the steering to be off. Make sure to check the alignment of both the front and back wheels, and adjust them as necessary. - Tire pressure: Uneven tire pressure can also cause the steering to be off. Make sure all tires are inflated to the recommended pressure. - Steering linkage: Check the steering linkage for any signs of wear or damage. Replace any worn or damaged parts as necessary. - Steering gear: The steering gear may need to be adjusted or replaced if it is causing the steering to be off. - Suspension: Issues with the suspension system can also affect the steering. Make sure to check the suspension for any damage or wear, and replace any damaged parts.
If you're still having trouble getting the Toro 360 quad steer to track straight, it may be a good idea to take it to a professional mechanic for further inspection and proper fixing.
Most all VCR players have auto tracking. When cassette is in the machine it will do the tracking for you. Sometimes a manual adjustment may be need if the player can’t find the right track for itself. When this happens it is usually a problem with the tape. Manual tracking adjustments are made on the player itself and not on the remote control. If you can’t find anything on the player that reads ‘tracking’, find it in the user guide. Sometimes cleaning the heads will solve the problem especially if all the tapes have the same issue.
MAke sure there is no debris in the tracks. MAke sure the rollers are not damaged. MAke sure that they are adjusted properly so that there is no upward motion on the screen. You may want to have someone lift the screen up as high as possible while the adjustment screws are set.
You will need a phillips screwdriver, non marring pry tool and a socket
set.The worst part is to pop off the
side view mirror cover on the door inside just above the door panel. Slide the
pry tool up and down until you hit the clip and gently push and pry the clip
out of each one of the receptacles.Unscrew the screws on the door trim and handles and lift the door panel
strait up then out with the window down. You should have access to the window
track and the mounting bolt. Loosen the lower part of the track and insert the
window in the track then tighten the mounting bolt. Test the window to make
sure the track is not bent or needs an adjustment.Reassemble the door if all looks good.
Hi, to me the problem sounds like the track rod ends need replacing these are what connects the steering to the hub now when you turn the wheel the track rod ends push the hubs in the way you want to turn but what happens ball joint on the track rod end get play in it is it allows the wheels to turn slightly on their own left and right now once these have been replaced you will have no problems. if the ball joints where to break you would lose control of the car as the steering wheel would not turn the wheels as instructed and they would be free to turn any way they liked, this would cause damage to the front wings and the hub costing a fortune to put right, but as it stands the track rod ends cost very little to buy and dont cost much to get replaced.
how ever this isnt the kind of job you can do yourself as you would need to get the tracking set up to ensure the wheels are driving in a strait line as their is adjusters that need to be set up after the track rod ends are fitted.
once you have the track rod ends ( tie rods also known as) fitted you will have no further problems and you will then be in full control of your vehicle it will feel a lot more responsive to your control so this needs doing sooner rather than later.
with an alignnment machine. If its a 4x4 and a strait axle then its not adjustable like all strait axle 4x4's Only the toe can be adjusted. Alot of trucks that are not strait axle come factory with the option to adjust those two but like my Expedition you need to purchase a part that doesnt come with the truck which usually runs about 75 bucks.
they made after some time VCR's with auto-tracking (digital controlled).
(exception:**IF you find some modern VCR's and have tracking: this control is pretty sure in the remote control or inside the menu**)
BUT
If you have problems as tracking point of view. (and not tracking in the remote control or any place else (menu) or front panel, etc
VCR needs a good maintenance. The sensor (control head) is dirty now. Or someone went inside the mechanism (I don't think so) and move something there. IN any sense the service is needed for this problem in VCR.
But if you mean the DVD
you need the technician to replace the pick up laser.
