Question about Refrigerators
Compressor fan on samsung american fridge freezer not working used a seperate power supply and fan works and the appliance works perfect also showing 23 e on display what does this mean the model numb
Compressor fan not working but works on a seperate power source and display showing 23 e what does this mean commpressor fan works perfect on a seperatre power source and appliance works perfect any advice would be most appreciated thankyou
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 23 Answers
THIS UINT HAS MULTIPLE PROBLEM
Posted on May 03, 2014
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
SOURCE: Samsung fridge freezer
Hi I have same problem as gordon. fridge 5 years old.
Posted on Mar 02, 2008
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
  • 117 Answers
SOURCE: I have a Samsung SRS2026
some great samsung diy stuff on this guys youtube channel
click link below
samsung fridge freezer diy repairs
cheers
Posted on Oct 02, 2010
  • 1044 Answers
SOURCE: whirlpool fridge will not cool.fan works but
Please check the cooling gas and the compressor as it is cutting out too often. You have to take the help of a technician.
Posted on Oct 11, 2011
Samsung american style fridge freezer, water and ice dispenser. Freezer, water and ice section fine. Fridge fan started running for extended periods and now is not cooling at all.
Which fan are you referring to? The interior one or the compressor fan? If you are talking about the compressor fan, that isn't good news. And could mean many things.
If you are talking about the interior fan, then the thermost is sensing that the refrigerator section is not cold enough. Which could me that the cooling tubes are blocked or clogged. The most likely is frost build up behind the rear panel of the freezer, meaning a defrost system failure. Hee are some links that might help you troubleshoot which component it is:
The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Jun 16, 2011 | Samsung RS2578BB Side by Side Refrigerator
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
REFRIGERATOR AND FREEZER STOPPED WORKING. COMPRESSOR IS HOT. FAN IS WORKING. IT TRIES TO COME ON. IT HUMS FOR ABOUT 15 SECONDS THEN STOPS AND TRIES AGAIN
replace the ptc overload relay on the compressor body,it merely unplugs and a new replacement plugs in,available from any appliance parts distributor,they get weak and will not stay "latched" to keep the compressor powered due to high heat and current draw after so long
May 25, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Fridge not working
Hi steven, Maybe this could help? Has anyone moved the settings on the fridge? Your fridge is actuallty controled by the freezer with a fan and flap in the fridge compartment. These sometimes ice up and do not let the cold air into the fridge if this is the case then i would switch it of and defrost it ( Yes it is supposed to frost free ) But they do fail. Check to see if it has two compressors on it? see if the fridge one is work and hot as it could be independant from the freezer depending on the spec!
Hope this helps?
Dec 28, 2008 | Refrigerators
Apr 01, 2008 | Refrigerators
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
