Question about Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater
Raypac HL 2 error code. How do I reset - Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater
  • 332 Answers
Unplug the unit for 1 to 2 minutes you can usally hear it click off when it is reset,
Posted on Jun 24, 2009
Water heater shuts off after 1 minute of use and displays code 13
1) Before calling service technician, Copy following link for Rheem tankless error codes and troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Error 13 can be combustion problem.
Call service technician.
Don't buy tankless since you generally cannot repair yourself, and they require yearly maintenance,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 30, 2013 | Water Heaters
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are considered start-point for troubleshoot.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
My water heater is flashing a cod 2 then 3 how can i reset this i lost ths manual
First thing to try for any electronic problem is unplug the machine and see if problem resets.
Before calling service technician, open following link for Rheem tankless resources including error codes and possible manual and Rheem chat and contact:
Error code 2 and 3 do not show on Rheem/Paloma charts or in typical manual.
Error codes are generally considered start places for troubleshooting.
Multiple error codes can mean PC board failure, but same problem on one unit can have different cause and solution than another unit.
Read the manual and make sure yearly maintenance is caught up.
Add a comment and say what you did to solve problem.
Jun 13, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
We have enjoyed a Rheem Thermostat and a Paloma Eco Sense tankless gas water heater #RTG-74XN-2 for 2 and 1/2 years, but now there are error codes flashing and resetting the thermostat doesn't hold. ...
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
http://www.fixya.com/tags/rtg_74pvn
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
How do I delete the stored error codes on my Rheem RTG-53PVN tankless water heater?
Some error codes cannot be reset...Example would be P/S failure on the PCB. Any other error, if you remove power for approx. 2 min - error should clear. - if not you need to contact Paloma/Rheem customer (800-432-8373) support
Nov 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
-0 82 error code PTG-74PVN Rheem tankless
I had the same problem, but when you change the PCB the chip has to be reset regardles of the elevation so it can communicate properly. The rest is easy, Find the DIP Switch located on the top left side of the PCB set switch #1 & #2 to the ON position push and hold the adjustment buttom till the display changes from flashing to illuminating the reset the DIP switch #1 & #2 to the OFF position and you are ready to go.
Aug 21, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Heater shuts down with C4-13 code
your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
Aug 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Bosch 1600H-LP Liquid Propane AquaStar AquaStar Liquid Propane Tankless Water Heater Logo
128 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
