Question about Grilling
Can not control the temperature
The temperature fluctuates
  • 1,162 Answers
If you are using a gas grill then, 1 open the valve on the fuel tank all the way, 2 be sure to check an see if the knobs controlling the flame on the burners are working all the way. if not replace them, propane is dangerous building up in grill an will explode. 3 make sure your hoses are not leaking, 4 you will lose control of temps if gas is low. 5 some grills are difficult to control temps because or the way burners are placed and height. it is a learning process with all grill. mine works different than my neighbors.
Posted on Mar 29, 2014
Temperature gauge keeps fluctuating whats the cause
Fiats have a reputation for electrical/electronic problems as they age and even when they are not very old they can manage strange things that even sometimes defeat the dealers, though the same can be said of many modern vehicles. I used to look after a Ducato motorhome and fortunately didn't need to get involved with much electrical work - the only faults were caused by the coachbuilders rushing around and being careless and not by Fiat.
I am not sure if the temp gauge is driven by the engine management or is a traditional circuit but either way the temperature gauge is in effect a voltmeter of sorts. Assuming the gauge is ok, the reading will only fluctuate if the voltage in the circuit fluctuates and that could mean the supply voltage is fluctuating or the resistance of the ground path is fluctuating.
With the traditional circuit the gauge is supplied by an electronically stabilised voltage and the ground path resistance is varied by the engine coolant temperature sensor and fluctuations could be anything from a faulty instrument voltage regulator, through faulty wiring or connections to the temperature actually fluctuating.
If the gauge is driven by the engine management the same approximately applies but checking the circuit becomes much more complex due to the need for circuit diagrams and specialised test equipment, though these would not be needed just to check the security of the gauge in the printed circuit of the instrument panel.
Mar 18, 2017 | Fiat Cars & Trucks
Amana fridge, AS2628HEK fluctuates in temp.Keeps repeating. Replaced the front display board, has been on lock for some time, ice and water were not operating, now it works again but temps not stable?
Replacing the front display board will not do anything other then tell the main control board what you would like to do. The control board that controls the operation is in the fresh food section up in the console area. What do you mean by temps not stable? Refrigerators do fluctuate in temperature especially after defrost.
Dec 07, 2016 | Amana Refrigerators
Kenmore 596.69142992 bottom freezer temp fluctuating from 10 to 40 degrees. Refrigerator maintains steady 40 degrees. No ice on coils.
The freezer temps fluctuate that much, I am thinking your cold control is going bad... Kenmore Refrigerator Temperature Control Thermostat W10752646
You can clean the fridge with warm soapy water and/or a hand steamer
Jun 29, 2016 | Kenmore Refrigerators
SAMSUNG REFRIGERATOR MODEL RT72KBSL1/2012, IS HAVING TEMPERATURE FLUCTUATIONS. for ex, temp reaches -20 than decreases to 9 degree n again -20 n vice versa. There is fluctuations also on display.
Sounds like your thermostat is sticking on and needs replaced. Before replacing check the setting on the thermostat. Almost all themostats are calibrated to maintain the proper temperature in the correct range when the thermostat is set to the mid position. If your thermostat is number 1 to 9, place it at 5. Refrigerator and freezer do not cool faster setting the controls to the coldest setting. This is misconception of a lot of people.
Sep 29, 2014 | Refrigerators
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Engine coolant Temperature gauge fluctuates
Watch the temp gauge when the electric radiator fans come on. The temp sensor that controls when the fan comes on may be faulty.
Oct 11, 2012 | 2000 Pontiac Bonneville
My oven temperature fluctuates widely (50 degrees) in both directions and won't hold a consistent temperature. I see from the manual that I can adjust the temperature up or down, but this won't address...
Try replacing just the thermocouple. You don't say how old the oven is, but the thermocouple is the device inside the oven that takes a beating (especially if it is a self clean model) and needs to be replaced every few years. A failing thermocouple allows wide temperature fluctuations.
Nov 18, 2017 | Whirlpool Ovens
Engine Temperature Fluctuation
fluctuation in temperature is usualy from low coolent level. a sticky thermastat could also be the culprit.
Nov 21, 2009 | 2004 Buick LeSabre
Temperature fluctuating
Fluctuating by how much? Maybe I can help you on this one
Aug 11, 2009 | Hyundai Motor 1998 Accent
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
Jan 26, 2009 | Refrigerators
Grilling Logo
32 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
