I have a GE WSX208H FRONT LOADER = WET CLOTHS
I have a GE WSX208H FRONT LOAD THAT GOES THOUGH THE COMPLETE CYCLE AND THE CLOTHS ARE SOAKING WET. ANY IDEAS? PUMP? THANKS!
  • 29 Answers
Pump you are correct. This company should tell all of us that there is a hidden drain plug that needs to be cleaned out every so often so that we do not burn the pumps up on these front load machines.
Posted on Jun 15, 2009
GE front loader spins slow
need the Model number to help you find the white tag and add the model number it inside the front door frame
Feb 03, 2018 | GE Washing Machines
The clothes are soaking wet after final spin in our Frigidaire GLFT2940ES1 front load washer
Good Morning Todd, thank you for your inquiry!
Often when clothing continues to stay wet, it is because your washer may not be reaching full speed during spinning cycle or not spinning long enough. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. Please wait roughly ten minutes and then turn your washer on. Select a normal cycle, allow cycle to complete and if resetting the power does not correct the issue you may wish to reach out to a professional who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Nov 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
My front loader is not spinning properly
You will need to remove the back of the unit and pull the boot off that goes from the tub to the pump and clear the filter.
Dec 10, 2012 | GE WSXH208A Front Load Washer
Cloths are wet after spin cycle
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
Nov 23, 2011 | Maytag EPIC MFW9700S Front Load Washer
Anytime this machine goes into a spin cycle it is grossly out of balance. we have tried adjusting the load; reducing the size of the load; we have gone to just one towel in the washer and still out of...
Are the locking nuts tight on all 4 legs? If not, tighten all locking nuts after leveling machine. Also, place a glass of water about 18" in front of machine while spinning and see if water moves. If it does, you may have flooring issues.
Sep 11, 2010 | GE Energy Star WCVH6260F Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Cloths still soking wet after rinse cycle
remove the front panel on the bottom look for a screw out filter bout 2 inches long youll see it screw it out clean the filter and reinstall the filter then the water should flow out on spin good luck
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
