Question about Refrigerators
Samsung american fridge freezer RSH5UBBP
Hi i have 23 e showing on display and the compressor cooling fan does not work i tried a seperate power supply and the fan works ok and fridge freezer works perfect so what else do i need to check thankyou
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
docjohn174
  • 943 Answers
SOURCE: fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
Posted on Oct 30, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Posted on Jun 20, 2009
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Fridge not working
Hi steven, Maybe this could help? Has anyone moved the settings on the fridge? Your fridge is actuallty controled by the freezer with a fan and flap in the fridge compartment. These sometimes ice up and do not let the cold air into the fridge if this is the case then i would switch it of and defrost it ( Yes it is supposed to frost free ) But they do fail. Check to see if it has two compressors on it? see if the fridge one is work and hot as it could be independant from the freezer depending on the spec!
Hope this helps?
Dec 28, 2008 | Refrigerators
Apr 01, 2008 | Refrigerators
A.
Feb 28, 2008 | Refrigerators
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
