NexStar TX Enclosure Problems
I recently harvest my Western Digital Scorpio Blue WD2500BEVS Hard Drive my from my old Dell Inspiron 1525. I'm trying to save the photos and videos I have on it. I purchased an Hard Drive Enclosure to store it in and connect to my Gateway Laptop viva USB. Unfortunately, it doesn't seem to be working when I connect everything together. Current Computer: Gateway NV53L23u Windows 8.1 Hard Drive Hoping to Get to Work: Western Digital Scorpio Blue WD2500BEVS Hard Drive Enclosure: Vantec NexStar TX 2.5-Inch SATA to USB 2.0 External Hard Drive Enclosure I was able to assemble the hard drive into the enclosure with no problem. And when I connect it to my laptop, it powers up and I can hear it spin with no problems. No clicking or unusual shaking. However, it doesn't automatically connect and doesn't seem to have a listing in "My Computer". I've checked under the "Device Manager" under Disk Drive and it's not there either. There's no listing for it either under "Disk Management". I know my USB Ports work fine as my other flash drives work on both of them. Does anyone have any ideas what I can do now? Thanks.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
I think it is because the hard drive you are using is too old for Windows 8 I think u will have to upload that to another hard drive
Posted on Apr 17, 2014
5 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Posted on Oct 22, 2007
wuntwowun
SOURCE: Computer not detecting NexStar 3 USB 2.0 External hard drive
I'm not a computer expert so I won't use too much tech language but after months of dissapointment, I finally got my NexStar 3 to work and it was actually easy!
At first I thought it was a driver problem so I tried to find a driver on line or in the disc provided (it wasn't neccessary as I run windows XP).
Then I actually opened the disc provided and found the PDF manual and opened that for a read (maybe the answer was in there?) Yep!! It has the answer you are looking for. Part of this manual 5.2 describes that "a partition is required" if the hard drive does not appear under My Computer.
To do this you:
Right click on your "My Computer" icon and choose "Manage",
Under "Storage" on the LEFT pane, select "Disc Management",
Find the drive (mine was around 300GB so I knew it was the one) at the bottom Left and "Initialize" the disc by clicking on "not initialized",
Then in the bottom RIGHT Pane, where the status bar is, Right click and choose New Partition,
Follow the directions from the Wizard. (Recommended partition type is "Primary" and file type "NTFS".
When this is done you should see your drive under My Computer.
NOTE: This formatted around 23GB on the newly created "E" drive I selected.
After this, by Right clicking the other unallocated area of the drive I went on to format the rest of the drive as a "F" drive which contains the other 256GB.
Hope this helps!
Keith in South Australia.
Posted on Sep 20, 2008
issken
  • 1472 Answers
SOURCE: IDE hard drive in Bytecc ME-535U2 enclosure not recognized by OS
smc4
There is a couple of things that could be going on. The first thing to check is that the drive did not get bumped off its drive letter by another device. If that is the case you just the to assign it a new one. The link below will help you do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
The other issue is the drive may have gotten disconnected improperly. I had the same problem with one of my drive on my XP system as well. It partly has something to do with the USB controller to my understanding. Alot of times if you plug it into another computer it will detect it and ask to run a scan to repair the drive. After this you should be able to access the drive on your XP system again. Note I have the best resolutes when I plugged the drive into my Vista system. So I would recommend trying to plug it into a Windows Vista or 7 computer to attempt the repair.
Let me know if you have any more problems or questions.
Issken
Posted on Feb 23, 2010
lock123
  • 6831 Answers
SOURCE: Unable to use Sabrent External HArd Drive Enclosure
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Western Digital Hard Drive Help Needed
Hi, The drive you are connecting to this USB enclosure can be set up as an auto select, master, or slave drive by changing the jumpers. Suggest to check your USB enclosure manual to see what is required for this device as to the configuration of the drive jumpers. Regards, Rongg
Mar 29, 2014 | Western Digital Computers & Internet
Using Western Digital Hard Drive as External Hard Drive Problems
OK! First of all try to disconnect all usb's from neighbouring usb ports as they might be using up too much current resulting in your HD not having enough power to be powered up properly! Also, try to use a different usb port.
If all these fail, please use a voltmeter (if any available...) to check if your devices actually function...
Hope this helps! If not, please report back!
Need disk manager
Boot the system from the Installation diskette. Install will happen automatically.
Jun 13, 2013 | Western Digital WD2500BEVS Scorpio 250 GB...
Jumper setting sata drive western digital scorpio scsi eide
Look for your model number on Western Digital's support site:
http://support.wdc.com/product/install.asp?groupid=701&lang=en
Apr 29, 2013 | Western Digital WD2500BEVS Scorpio 250 GB...
Connecting a WD2500BEVS hard drive to USB
You can get a hard drive enclosure for a few bucks to use the drive as a external drive. All the files are there that way.
Jan 24, 2012 | Western Digital Scorpio Computers &...
I want to use my wd2500bevs as an external drive but i don't know which style enclosure to buy. any suggestions?
pick one
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007705%20600006255%20600006269&IsNodeId=1&name=SATA
Jan 21, 2011 | Western Digital WD2500BEVSRTL Scorpio...
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Need driver for Western Digital Scorpio (WD2500BEVS) hdd. Cannot install Vista on hdd because system does not recognize hdd. Have no idea where to find these drivers.
Hi raider4123,
The Western Digital Scorpio (WD2500BEVS) doesn't come with a driver, but I have an idea that perhaps you may have a pin setting wrong, making the drive not recongizeable. Here is the information on setting the pin on the back'
If that doesn't seem to solve the problem, then I'd run the WD Lifeguard software, that will detect any problems and correct them for you. You can find that software HERE.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
Sep 15, 2009 | Western Digital Computers & Internet
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
