Question about HEWLETT-PACKARD Computers & Internet
Monitor reads "No Signal" when I power up my HP p6210y. Tried new video card. Tried new motherboard. Tried resetting CMOS. Still says "No Signal".
Lights come on, fans come on, HDD spins, Monitor says "No Signal" and there are no beeps or anything. I'm stumped.
  • 35 Answers
Well this must be fault with the monitor.
Posted on Mar 29, 2014
  • 4 Answers
SOURCE: HP PAVILION 760n
tell me if there is something i need to know like: what were the things that you've doing with your computer before the problem happened?? are there any recent hardware/software changes?? tell also your OS- is it XP or Vista...
first, let's try to check if the problem is with the monitor or not,okey? try unplugging the monitor blue connector at the back of the tower.and make sure that your monitor is turned-on.If you can see a colored bars displayed.you monitor is okey.if not, try a known good monitor...if it woks the problem is with the old monitor.(resolved)
2 (if not)
Now, complelely turn off your computer and try reseating all the cables, and your hardware components such as memory,video card,IDE cable and so on. but before doing so, unplug the power cable and then push the power button to drain the power.after reseating everything, plug back the power cable and turn on computer.try listening to the tower,tell me if you can hear some beeps also.
if no video issue is still there, try putting a known good video card if you have any.if a known good video card works then the problem is with the old one..
if the problem is still there after everything that you've done try calling the manufacturer. this is lead to a motherboard problem but try to call them first.
Posted on Jan 17, 2008
Fixe_You
  • 1800 Answers
SOURCE: No video on Dell C521
in this case Graphic card is faulty try no built-in/intergarted graphic card such as Nvidia or sis that u computer would support.
Posted on Mar 14, 2009
byteguy
  • 2229 Answers
SOURCE: No video on new Gigabyte GA-MA770-DS3 motherboard
There are a couple things that you need to look at. The first is your power supply. I've had computers seeming to run fine with no video. Turned out to be bad power supplies.
Does your video card require a power connection? Many high-end video cards need an external power connection. If the card has a power connection, use it.
Have you gone in and checked the cmos settings? What does it say (if anything) for the default video?
Now remove all connections to drives (hard drive and CD and try for video. Try it.
Next, if possible, swap out memory.
After you've tried everything (including maybe burning incense), time to try a new motherboard.
Posted on May 27, 2009
bluecrash
  • 106 Answers
SOURCE: Fan works but no beeps, no video signal. Tried some suggestions.
sometimes pulling the power cord out of the pc and then replugging it will let it reboot. for some reason these machines die, and they will not reboot until you take all the power off the motherboard for about 10 seconds.
Posted on Jun 25, 2009
  • 145 Answers
SOURCE: A 14 month old Acer aspire M1640 wil not show any
YOU MAY HAVE A BAD MOTHER BOARD
Posted on Jan 08, 2010
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
HP Pavilion Slimline s3120n. turn the computer on and is sounds like it is starting normally but No Video. I have tried disconnecting all extra components from the motherboard, resetting the Cmos with...
Try the display on a different PC. The on board video may be defective, if so you will need to buy a new video card. Check to see what type you need. Good luck. I hope this helps...Have a good day.
Apr 26, 2011 | HP Pavilion Slimline s3120n Desktop PC
My HP Pavilion a6300f powers up but no signal to the monitor
It could be the motherboard, try resetting the the bios first by either taking the lithium cmos battery out and then replacing after 30 secs or finding the the cmos jumber and unshort it for 30 secs, and reboot the mechine.
If the same and no monitor responce then the onboard graphic electronics may have failed, the motherboard does have a AGP expansion slot which you may want to test with a graphics card to see if that will work.
If you find that you do have to replace the motherboard, try to find one that uses the same processor and memory that you already have, that way you will keep expence down to a minimal.
Replacing the motherboard will mean you will have to contact microsoft to give you the installation codes for the operating system to work with the new motherboard, when you boot for the first time with the new motherboard fitted you will have to phone the number on the screen to reregister the system just follow the instructions, it is quite self explanetry.
Once all booted up and drivers installed the computer should run as normal, as for the hp recovery disks it should still work as all the information on the disk is on the harddrive any way, the only thing you would need to do is keep the motherboard installation disk with all the drivers on.
hope this helps.
Mar 23, 2010 | HP Pavilion Desktop a6300f Intel Pentium...
No video output
I'm glad resetting the CMOS fixed it. (Posted as solution so you can rate the response.)
Mar 22, 2009 | EliteGroup NFORCE 570 SLIT-A Motherboard
No Video Output.
Try without any RAM and see if there is a beep...if there is then mobo is ok. If no beeps still. Check the CPU. Also check the PSU if its giving adequate power to all the added cards. If possible try with another PSU. Try clearing CMOS as well. If all these doesn't do any good to the mobo, I think its time to RMA the mobo. Have a great day!
Jan 31, 2009 | ASUS M2N-SLI Deluxe Motherboard
NO SIGNAL TO MONITOR
change the memory card, then reset the cmos. if problem persists change the video card, its probably bad.
Jan 24, 2009 | Intel Motherboard
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
Monitor light blinks
have you tried hooking the monitor up to a known working motherboard video or video card in a motherboard? it sounds like you may not have the settings in the motherboard correct jump the cmos clear to reset the motherboard connect everything then turn on your monitor then turn on the computer and get back to me in this thread.
May 05, 2008 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
