Question about All-Pro Heating & Cooling
All pro heater runs but will not lite
Heater runs but will not lite
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
Runs for 2 mins & shuts down now wont lite off running diesel with treatment
alsteadironw,
All these type heaters (Reddy, All Pro and Master heat) were made by DESA international.
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains this common problem, where to get the repair parts and how to do the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 25, 2011 | Reddy R155D Utility Heater
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
We have a laars lite 2 pool heater , the pilot is lit but the unit will not fire up
With these pool heaters, there are a couple of things that you can try before you call a pro. First, make sure that your gas valve knob is turned to the on position. Secondly, you could have air in your gas line. Cycle the ignition sequence until all air is out of the line. It could also be that your gas valve is malfunctioning and needs to be replaced.
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Got a 15000 btu that the igniter lites but no fuel seems to get through,checked hoses thier clear any ideas thanks joe
Check the rotor (black circle w/ 4 blades inside) for damage or wear. Clean or replace filters. Also clean your nozzel. The manufacturer has a website that offers technical support manuals... www.desatech.com . I hope this helps.
Jan 29, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Gas pool heater above ground will lite and feel heat then shuts off
do you have flow through the heater, pump for pool running , is your aquastat[ water temp control] set correctly
May 11, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heater will not stay lite
Sounds as though your heater is a bit different than mune - I havwe no gas supply button, at least I don't think so. I just replaced my nozzle however at the recommedation of a recent contact to this site. It worked. The replacement packaging suggests annual replacement, so I think I was due - after ~12 years!
Jan 31, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
26 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
