Question about Western Digital Computers & Internet
Using Western Digital Hard Drive as External Hard Drive Problems
I recently harvest my Western Digital Scorpio Blue WD2500BEVS Hard Drive my from my old Dell Inspiron 1525. I'm trying to save the photos and videos I have on it. I purchased an Hard Drive Enclosure to store it in and connect to my Gateway Laptop viva USB. Unfortunately, it doesn't seem to be working when I connect everything together. Current Computer: Gateway NV53L23u Windows 8.1 Hard Drive Hoping to Get to Work: Western Digital Scorpio Blue WD2500BEVS Hard Drive Enclosure: Vantec NexStar TX 2.5-Inch SATA to USB 2.0 External Hard Drive Enclosure I was able to assemble the hard drive into the enclosure with no problem. And when I connect it to my laptop, it powers up and I can hear it spin with no problems. No clicking or unusual shaking. However, it doesn't automatically connect and doesn't seem to have a listing in "My Computer". I've checked under the "Device Manager" under Disk Drive and it's not there either. There's no listing for it either under "Disk Management". I know my USB Ports work fine as my other flash drives work on both of them. Does anyone have any ideas what I can do now? Thanks.
  • Ant Apr 05, 2014
    What kind of drive update software would you recommend? And what would you suggest for a SATA to Usb be converter? I really don't know much about this kinda stuff, so any help is appreciated.,
    Habit-Forming:
  • 98 Answers
OK! First of all try to disconnect all usb's from neighbouring usb ports as they might be using up too much current resulting in your HD not having enough power to be powered up properly! Also, try to use a different usb port.
If all these fail, please use a voltmeter (if any available...) to check if your devices actually function...
Hope this helps! If not, please report back!
Posted on Mar 30, 2014
  • 5 more comments
  • Ant Mar 31, 2014
    I removed my Wireless Mouse and it's receiver then reconnected the enclosure with the harddrive and it still doesn't show up. I even set the laptop to High Performance mode to see if it would and it didn't. I tried the enclosure with the harddrive with a friend's laptop and it also didn't work there. Unfortunately, I don't have access to a voltmeter, so I can't test it as you suggested. Do you have any other ideas?
  • Iron Fist
    Iron Fist Apr 01, 2014
    You said: "I tried the enclosure with the harddrive with a friend's laptop and it also didn't work there..." This leads to 2 possibilities: 1. Either the enclosure with the harddrive is not functional (assuming his laptop is fully functional)... 2. Are you and your friend (where you've tried the enclosure with the hraddrive) using an old operating system like windows xp for instance? If yes, then you might need a CD or generally an extra driver in order for your system to recognize the new device (I've seen that before...)
  • Ant Apr 01, 2014
    1) It's very well possible that the enclosure is a dud, it has some light brown burnt on dirt around the pins. I'm contacting the seller as it about this possibility. 2) We both have Windows 8.1 on our laptops. The hard drive did come from an Window's Vista system. Do this have an possible effect on the issue? If so, How would I go about fixing it?
  • Iron Fist
    Iron Fist Apr 02, 2014
    Well , it is possible that 1) is the case, but regrading the second one, you could try to connect the enclosure with the harddrive on your laptop and run a full scan using some driver update software to check if it can detect your "hd set". Also, try to look for any specific (dedicated) software for Western Digital Scorpio Blue WD2500BEVS Hard Drive and try installing and running it (check if it needs to be run using compatibility with Windows Vista...). If this does not work then please try a SATA to usb converter and attach it a usb port of your laptop. If this does not work, I think you will have to use a Voltmeter as I've suggested on a previous post.
  • Ant Apr 05, 2014
    What would you recommend for driver update software? I would prefer freeware if possible. And what would a SATA to USB converter look like? This isn't my area of expertise so any help is appreciated.
  • Iron Fist
    Iron Fist Apr 05, 2014
    Well, as far as driver update software is concerned, an example would be this one:
  • Iron Fist
    http://slimdrivers.joydownload.com/?c=18... ,which is freeware (just an example... No promotion, no advertising, nothing) Also, regarding the ide to sata converter, please check these out:http://www.ebay.com/sch/i.html?_trksid=p... (again, I do not mean to promote or advertise anything or anyone...)
Western Digital Hard Drive Help Needed
Hi, The drive you are connecting to this USB enclosure can be set up as an auto select, master, or slave drive by changing the jumpers. Suggest to check your USB enclosure manual to see what is required for this device as to the configuration of the drive jumpers. Regards, Rongg
Mar 29, 2014 | Western Digital Computers & Internet
NexStar TX Enclosure Problems
I think it is because the hard drive you are using is too old for Windows 8 I think u will have to upload that to another hard drive
Mar 29, 2014 | Computers & Internet
WD1600BEVS Scorpio pin settings
You shouldn't have any problems. The computer uses SATA drives and the drive is SATA and is also a 2.5" laptop HDD. Make sure that you have a way to install an OS , etc
Nov 13, 2013 | Western Digital WD Scorpio Blue WD1600BEVS...
Need disk manager
Boot the system from the Installation diskette. Install will happen automatically.
Jun 13, 2013 | Western Digital WD2500BEVS Scorpio 250 GB...
Jumper setting sata drive western digital scorpio scsi eide
Look for your model number on Western Digital's support site:
http://support.wdc.com/product/install.asp?groupid=701&lang=en
Apr 29, 2013 | Western Digital WD2500BEVS Scorpio 250 GB...
Connecting a WD2500BEVS hard drive to USB
You can get a hard drive enclosure for a few bucks to use the drive as a external drive. All the files are there that way.
Jan 24, 2012 | Western Digital Scorpio Computers &...
I want to use my wd2500bevs as an external drive but i don't know which style enclosure to buy. any suggestions?
pick one
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007705%20600006255%20600006269&IsNodeId=1&name=SATA
Jan 21, 2011 | Western Digital WD2500BEVSRTL Scorpio...
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Need driver for Western Digital Scorpio (WD2500BEVS) hdd. Cannot install Vista on hdd because system does not recognize hdd. Have no idea where to find these drivers.
Hi raider4123,
The Western Digital Scorpio (WD2500BEVS) doesn't come with a driver, but I have an idea that perhaps you may have a pin setting wrong, making the drive not recongizeable. Here is the information on setting the pin on the back'
If that doesn't seem to solve the problem, then I'd run the WD Lifeguard software, that will detect any problems and correct them for you. You can find that software HERE.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
Sep 15, 2009 | Western Digital Computers & Internet
Computers & Internet Logo
325 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
