Question about Vizio Televison & Video
Vizio won't turn on
My 47inch vizio went out after a power surge. The tv would not turn back on when using the remote and also when using the remote. I opened the back, nothing smelled burn. I plug the power cable after I opened it, it turned back on. I closed the cover and it would not turn back on. After a few tries, I closed the back and the tv worked for a few weeks until I turned the breakers off because I was working on electrical in the house. The tv would not turn back on. I did the same thing, opened the back and it turned on once and that was it. It never turned back on again, the vizio emblem never turn orange when plugged. I ordered the power board first because it was cheaper ($47), still nothing. I ordered the main board ($119) and still nothing. The emblem still does not work. Help.
4 Suggested Answers
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
  • 11361 Answers
SOURCE: I have a 42" VIZIO 1080P T.V. It worked great a
You need to troubleshoot the problem and I am not trying to sell you parts, so please read my guides first.
Since the sound and picture went out, the problem can be the power supply (right now the 5vdc tsandby power supply is working) or main board, or backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Please post back what you find.
Posted on Dec 03, 2010
  • 10515 Answers
SOURCE: I purchased 47" vizio and
I am sorry to hear regarding the trouble. To eliminate bad surge protector, kindly plug the TV directly into the socket.If problem still persists, then it would confirm an internal failure and needs repair. Unfortunately, there is no small fix for the same. If you have electronics repair experience and would be able to perform the repair, revert and i would be able to follow up.This is most probably an issue with power supply board. Bad caps often cause the same problem. Do provide with the model number so that i could tell you the components that needs to be tested and replaced,if find faulty.
Thanks and Regards
Posted on Jun 15, 2011
No power on Vizio VO47LF 47inch
power supply board faulty.....
Dec 04, 2016 | Vizio Televison & Video
Blue screen, no picture. What's wrong?
The board where the power button is located (same board for the other buttons too) is probably bad. It's all one board, which tells the power board to come on. If this happened after a power surge, and you're not using a surge protector, multiple boards can be bad. (You can't just plug these fragile TV and Blu-Ray players into the wall outlet. Eventually a surge will destroy them). Ps... A lot of people are suddenly making this same complaint with Vizio TV's.
Mar 03, 2016 | Vizio Televison & Video
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
65" vizio new and my remote won't work
i think that you have to program the remote
Mar 24, 2013 | Vizio VBR220 Blu-Ray Player
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
Power surge while it was turned off. when power was restored 47" vizio lcd/hdtv screen flashed then went black. won't turn on even with vizio trouble shooting steps, repair shop says needs a new...
sounds like you have a bad back light inverter board and it needs to be replaced. if it is still under warranty then try to get the manufacture to repair it for you. just don't tell them its from a possible power surge. check sharp's web site for more info. i think vizio is made by sharp electronics.
Aug 25, 2011 | Vizio Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Loud pop and now Vizio 37 TV will not work
This sound like the power supply board went bad. You should check that. See if the fuse on the board is blown first.. You can get a "pulled" power supply board on the net if needed.
Mar 07, 2009 | Vizio L37 Television
Televison & Video Logo
32 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
