Question about Stanton ST-150 Turntable
Stantonst.150 turntable platter spins unevenly
When watching my stantonst.150 turntable platter spin the platter spins unevenly in relation to the level plinth surface though it seems tobe seated properly in the spindle bearing and there is no noticable effect to the sound coming out my stereo speakers.........
    Sergeant:
  • 432 Answers
Well, you have the rotor, which has above the conus where you put your platter on. But the rotor needs to be kept in space, so it can spin,
which offcourse in the is done by (too soft) bearings, but the bottom of the the rotor(which looks the same as the 'pin' where you put you vinyl on, just leans on a piece of metal, instead of a technics where it falls in a shaft too keep it is place.
You undestnd that the strength on the bearings of a st150 is much higher, especially when scratching. Besides that, the high torque works 0,2 sec and then an optocoupler samples the speed of the rotor. And it's easy:on the underside of the rotor ,there's a plastic round disc puled over the rotor and kept on his place by a plate and 3 screws, with on the outside just
Posted on Mar 31, 2014
  • jason heatley
    jason heatley Apr 01, 2014
    THE ANSWER to the problem to my Turntable was cut off at JUST....
  • Audio Service Clinic Nov 27, 2014
    What Richard is trying to say, simply put, is that the spindle bearing that the platter is sitting on, is either loose or worn out. Thanks to Richard for his input, which is correct, even if it's not worded correctly. :-)
2 Suggested Answers
STYLUSCITY
  • 271 Answers
SOURCE: Hi,My platter on my Stanton T.120 will no longer
lift the platter and check the belt is on correctly. styluscity@gmail.com
Posted on Sep 01, 2011
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
My turntable appears to be uneven. it looks like a rolling hill when spinning, can this be fixed
Is it just the matt that records sit on that's the problem or the whole platter?
If it is the matt you can peel it off and get a new one from somewhere such as as Amazon. It doesn't have to be the same brand as the turntable as long as it fits on.
Just search for "turntable matt".
If the platter is the problem it might be caused if the platter is plastic by either a chemical or heat warping the platter. Has it been exposed to the sun for example? Some chemicals such as oil and polish can cause it to bend out of shape.
It's likely if the platter has warped that it will need to be replaced.
May 15, 2015 | ION Audio Audio Players & Recorders
Stanton st.150 turntable sins unevenly
That is a lack of maintenainance, but your real problem is that your
voltage regulator from -24 en 24v gets to hot, since the stanton has crappy everything, where cheap build and often the components aint screw against the cooling block, so first check that and well , there about 60 crappy su\'scon caps that needs replacement. It\'s a tt from hell with the useless weight. Your system started spinning hard, cause the thermal protection started to work. Overheating, since most peoples set the start and stop torque set at the highest point, and with the small cooling blocks you get a problem and by pressing the platter, you ask for more current and that was just too much, if your bearings were that bad you assume , you have heart a lot more noice.
gr richard
Apr 01, 2014 | Stanton ST-150 Turntable
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
Hello My turntable do not spin
This turntable is a belt driven type. The belt wraps around the underside of the platter and the drive motor spindle. If the belt has slipped off, broken or is so old that it is slipping - the platter will not turn. Usually you can remove the rubber cover on the top of the platter to use access openings beneath to put the belt back on.
The turntable product brochure, owner's manual and related info is available from Pioneer, here.
I hope this helps!
Dec 03, 2010 | Pioneer PL-990 Turntable
I HAVE A 1951 AMI D-80 JUKEBOX,THE TURNTABLE IS JAMMED.
There are two motors with beige/tan plastic covers over them, one on turn table platter and the other on the record changer mechanism table. Take the cover off the one on the turntable and spin the motor by hand. Depending on how you spin it the arm will either go back up or down
Jan 03, 2010 | Audio Players & Recorders
My turn tabel isnt spinning
The drive belt has come off. Open the lid. Remove the rubber mat on the platter. Remove the C-shaped clip from the center of the turntable. Lift the platter up and off. Find the flat rubber band that connects platter and the motor. Plug it in and verify that the motor turns when you press power, then standby, then phono.If the motor spins, unplug power and place the drive belt on the underside of the platter. This is not easy, but it can be done with patience. Then put the C-clip back on and replace the mat. Congrats!.
Oct 10, 2009 | Philco 841205 Turntable
Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Nov 06, 2008 | Stanton ST-150 Turntable
Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Jul 24, 2008 | Vestax PDX-2000MKII PRO Turntable
Open Questions:
Stanton ST-150 Turntable Logo
176 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
