Question about Cuisinart Electric Can Opener
Wont open cans
Cuts into lid of can and then stalls
Ford taurus SE 2007 model wont start after bumped to barrier
Open the trunk of your car. And on the left side close to the hinge that holds your trunk lid open there will be a small round opening. Look inside the opening and you will find a red button. Push in to reset. This is called the inertia switch. Which was designed to cut off your gas source to your vehicle in a collision. If you do not find it there refer to your owners manual. Once it starts , if it cuts out again easily replace the switch. It can be a headache if you just keep resetting it...
Mar 30, 2014 | Cars & Trucks
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
I have a GE profile topload washer PTAN9455MGG displaying F4 Error code and no answers.
tou can test this by jumping the lid switch , to do this you cut the 2 wires and twist them together . now this will not permanently fix this it will run a cycle and then fault out again . It has to detect a open and close of the lid . the switch is cheap and its a easy repair
Feb 18, 2013 | Washing Machines
Hamilton beach can opener 76606 not cutting lid off - repairable ?
I have a hamilton beach can opener 76606 has quit cutting can lids off.
May 23, 2012 | Hamilton Beach 76606
Nissan sentra 2006 My trunk wont open && I spent 2 1/2 hrs trying to break in from the back seats. trying to reach the seat release but cant. The key or remote wont open it. The car latch wont open...
does the key turn the trunk lock?if not theres one issue right there.the other may be that the valet lever on trunk latch assy. may have inadvertantly been engaged if deck lid was slammed closed.the release solenoid will make noise when activated by fob or lever in car but because of valet being engaged cannot release latch.does key unlock glovebox?if not this may also be a valet key cut.contact nissan dealer to cut regular key.ive seen the slamming the deck lid scenario a million times as the valet lever takes hardly any effort to engage.good luck and let me know how you make out.
Feb 07, 2011 | 2006 Nissan Sentra
Machine will agitate until lid is open? will not spin unless I play with the lid...i can see the motor start to turn then it cuts off...after some playing with the lid I can get it to spin?
The lid has to be closed for agitate and spin. The lid switch is loose or defective.
Open the control console to retrieve the mini service manual.
Follow the steps to access the lid switch and repair.
Feb 17, 2010 | GE WDSR2080D Top Load Washer
Whirlpool Washer stalls out on rinse cycle
This is likely a lid switch problem. They tend to get weak and work sometimes and sometimes not. When it stalls like that try pushing down on lid and see if it kicks in. If so you need to replace the lid switch
May 11, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Cannot get the lid to unlock
Hi kirklin
if you open the detergent lid there should be a red or green cord just pull it and it should open it.
brent
Sep 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Tub will fill the machine will agitate but when time to drain nothing happens
you need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch p#3949247(if that vcorrect mod num lsq9564j
Feb 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing a comforter and machine stalls. Code says Door is open..it isn't and will not let me open it. What now?
The only Reset is unplugging waiting a few mins and plug it back in. If not perhaps the lid locks have failed.
Jan 20, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Cuisinart Electric Can Opener Logo
127 people viewed this question
Top Cuisinart Home Experts
john h
Tom Chichester
Are you a Cuisinart Home Expert? Answer questions, earn points and help others
