Question about Sharp Shift 3 The Black Series Deck Usb Turntable Converter
I need driver windows 7 for this turn table - Sharp Shift 3 The Black Series Deck Usb Turntable Converter
I have misplaced the cd for installation of my panasonic KX-FLB802 on my newly purchased laptop which has windows 7 version installed. Can you help with providing information on how I can download the...
Hi Welcome to FixYa!
-Sorry to hear that you lost your installer CD for your printer. But you don't have to worry. Your laptop that has Windows 7 on it won't need an installer anymore. Its because of the wide drivers database that Windows 7 has. You could refer to the link below to check that your printer is actually compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Panasonic%20KX-FLB801%20All-in-One%20Printer&v=Panasonic&uid=KXFLB801&pf=5&pi=8&s=Panasonic%20PV-GS65&os=32-bit
-All you need to do is plug in the printer and it will automatically install the driver.
-If you need the operating instructions for your printer, you could download the PDF file here on this link: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/Operating-Instructions/model.KX-FLB801.O#ts
Hope this would be a big help!
Jun 21, 2011 | Panasonic KX-FLB801 All-In-One Laser...
I can not draw a table in microsoft word
hi ermelitacapa,
To create a table in Microsoft Word please do the following:
1. Go to the Table menu and select 'Insert Table'. The Insert Table window will open.
2. Select the number of rows and columns you want in your table.
3. Select the column width (up to 22 inches) or choose 'Auto' to have the column with adjust automatically, making the table extend across the width of the page.
4. Select the AutoFormat button to select one of Word's pre-formatted table styles. The Table AutoFormat window opens.
5. Click one of the styles in the Formats box in the upper left side of the window.
6. Preview each format, after selecting it, in the Preview box in the upper right side of window.
7. To customize a pre-selected format, select or de-select the borders, shading, font, color, heading rows, first column, last row and last column boxes.
8. Select AutoFit, and Word will automatically fit the table to your page.
(To manually change the width of a table or column after you have created it, use the mouse to place the pointer over the vertical line you want to move. When the pointer turns into a double-headed arrow, drag the line to the position you want it in the table.)'
I hope this helps!
** If you find this information helpful please leave feedback to help us help others **
Feb 24, 2011 | Microsoft Windows 7 Home Premium 64BIT...
The Windows 7 mini drivers for the Xerox 7132 only provide a limited feature set. If I install the Windows 7 driver for the Xerox 7232, will it work with all features on the Xerox 7132?
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
Jul 14, 2010 | Xerox WC7232 Printer
I want to install xp on my presario cq40 315 tu pc i heard of a sata driver to install on pc then i can instal xp..... plz give me proper instructions, with the link if any to download any softwares...
Initially you have to download sata driver for the model of your laptop from the manufacture website.
After downloading driver you have use the nlite software to create xp cd boo table with sata driver.
you can get details regarding the creation of bootable xp with sata driver from the following link
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
you can download software from http://www.nliteos.com/download.html
Mar 03, 2010 | Compaq Presario Notebook
Sharp Shift 3 The Black Series Deck Usb Turntable Converter Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
