Question about GE Spacemaker GTUP270EMWW
Washer does not work but dryer does
Lights won't even come on to check error codes nothing
  • 509 Answers
Sounds like a safety switch is bad like door switch, or a wire has come off or disconnected somewhere. it will have to be taken apart to fix it. If i can help further just give me a shout.
Posted on May 30, 2014
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Dryer won't spin belt good
Your problem says dryer but the category says washer. I wrote this answer thinking the problem was washer. Sorry but I haven't had opportunity to fix my dryer before so can't help you there. If however your problem is the washer (or is anyone else is reading this), please read on... you should find some ideas here.
First you have to check the error code. If your washer does not have a digital display you have to do the following:
1. press any button to "wake up" the machine.
2. press and hold the start and pause buttons.
3. count the flashing lights.
a) first the five lights plus the start light will flash. Count.
b) then the start light will flash. Count.
4. error code is E +# of times in a + total # of flashes in a and b.
Example: flashes start light plus all five lights 4 times, then a pause, then start light alone 3 times. Error code is E47.
There are lots of error codes but E47 and E43 are both door problems. Check out the following document for a lengthy (but understandable) troubleshooting guide. E47 and E43 both say to do Test 9, which is test the resistance of the PTC. If it's not working then you have to replace the door latch assembly (about $80), if it reads around 1500 Ohms you have to replace the control board (about $250).
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf
First, let me say that I have no idea how to test the PTC but it can't be hard with a standard multimeter (I will be doing this tomorrow with my Dad).
Second, the removal to access the door latch assembly is stupid easy - check out the following YouTube.
http://www.youtube.com/watch?v=prkM2XMoOJk
Third, if you have a different error code just look up the test in the manual document above.
Hope that helps!
Dec 15, 2012 | Frigidaire Affinity ATF7000E Front Load...
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Kenmore 82822 Electric Dryer
Error code dL F is popping up on washer. Door will not open, is locked but light will not come on on panel where is says "door locked." Can't wash, nor get the clothes out that need to be washed.
Fdl is a code that indicates a door lock error. This error occurs because the washer senses that the door cannot be locked (even if it is). The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore Elite HE4 Electric Dryer
C45072 Kenmore washer will not start. Did one
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Cheers!
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
GE Spacemaker GTUP270EMWW Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
