Question about LG Shine CU720 Cellular Phone
Failed to register 3g at&t
Can't get signal
What do i do when my mobile phone says 'mobile network unavailable?
The ideal solution temporarily is to find a spot with wifi.
The "network is probably not your phone's problem. Its either the network having problems or your location.
The problem is that u cant get a proper network at that place. In your phone, come to the home screen, where wallpaper & other options are displayed. There'll be two indicators, one of your battery, & the other, of the same style & behaviour, the network indicator. That tells you about your signal strength.
First, restart your phone, it'll refresh the network. If there's still a problem, then it means that u cant get a proper connection to that network. Then what u should do is- If you're in a crouded area, or in a room, go out in the open. Or if you're in a village, then you cant find signal there easily. But rather travelling for good network, you should use someone else's phone which can get signal or a landline. Or if you want signal, you'll have to travel to some distance, or maybe even a long distance. That's all which can be done.
Jul 31, 2014 | Samsung S5830l Galaxy Ace Black Unlocked...
Tip
How to use make video call on an iPhone 3G using Live Link
At first, we thought video calling with FaceTime on the iPhone 4 was remarkable. Most of us didn't know that in Japan, video calling has already been possible on the iPhone 3G. Using the back camera, people can make video call over wifi using Live Link 3G, from Yudo, Inc. <br /> <br /> This app is now available for iPhone 3G users in the US & probably the whole world. <br /> <br /> To make a video call, you must install the app on both the caller & the receiver's iPhone. The app also works for the iPhone 4 & iPhone 3GS. <br /> The app is approved by Apple so you don't need to jailbreak your iPhone to install it. The only requirement is for your iPhone to have iOS 4.0 or later versions, installed. <br /> <a href="http://itunes.apple.com/ca/app/live-link-3g-fine-3/id360021071?mt=8"><b>CLICK HERE to download Live Link 3G</b></a> or use thie link below: <a href="http://itunes.apple.com/ca/app/live-link-3g-fine-3/id360021071?mt=8">http://itunes.apple.com/ca/app/live-link-3g-fine-3/id360021071?mt=8</a> <span><br /></span> <span><br /></span> <span>Once you've installed the app, here are the steps on how you can make video calls on it.</span> <ol> <li><span>Open Live Link 3G and register your account. Don't worry, there's no subscription fees there.</span></li> <li><span>Confirm your registration by logging in to the email account you used to register.</span></li> <li><span>Go back to Live Link 3G and</span></li></ol>
on Mar 27, 2011 | Apple iPhone 3G
IBM ThinkCentre 8172-MM4 desktop pc. I am getting low voltage measured on the USB ports(all) when I have a few things plugged in... 320G HD{rear ports}, 3G modem {Front ports}, SD card reader {Front ...
The main pc power supply is failing, this is an easy fix with any generic pc power supply.
most competent persons can do this themselves with a little caution and a photograph before you remove the old one...!
good luck !
Mar 30, 2017 | Computers & Internet
I68+ Not registering on O2 Irl Network
After further research into the phone, I have discovered that it does not support any 3G network and as vodafone and O2 in Ireland are now 3G networks, neither the I9 or the I68+ will work on these networks. They only support 2G networks(GSM). Will work with Meteor Irl but this network is in the process of changing to 3G so these chinese phones will soon be useless in the Republic of Ireland.
Aug 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
3g connecton - AT&T service - I keep getting
first, check the 3G led is on, if is on, then open the 3g connection mamager and wait about 1 minute, if doent appear signal, download the lastest drivers of 3G Modem and the updated 3g connection manager here: http://support.acer-euro.com/drivers/notebook/as_one_150.html
Jul 07, 2009 | Acer Aspire One PC Notebook
Getting mg as sim card registation failed and also signal on&off
hi my friend.where u gave your phone?they have flashed your phone with a wrong flash file!there is 2 model of this phone i think & another is blue,go again & ask it to flash with true file.& also say to register your phone.i think they have deleted your IMEI code.
Jan 26, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
LG Shine CU720 Cellular Phone Logo
19 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
