Question about Sunny Health & Fitness 3 in 1 Vibration Trainer
Power socket black holder with screws came off the inside of socket is good just need that back holder that fits around power socket
The microwave has no lights, power or anything. The socket works but it's like the microwave is receiving no power.
You probably have a blown fuse inside your microwave.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 06, 2015 | Microwave Ovens
How to find fuses on my GE Spacemaker XL microwave model# JVM1340 WW
First thing is make sure you unplug the power cord. Turn the microwave around and remove the screws that hold the cover on. Remove the cover and look for where the power cord goes through the back of the unit. Follow the black wire coming from the power cord and that will take you to where the fuse is located. It might be on a small circuit board or mounted in a fuse holder or it might have an inline holder. Make sure that you replace the fuse with the same amperage fuse as you take out. You will find the amp rating stamped into one of the collars on the fuse. Good luck!
Feb 27, 2015 | GE Microwave Ovens
How to put back the part where the needle is attached?
youtube has good videos. Check this link, you will probably be able to see how the part is attached. Brother XL 6562 YouTube
Jul 31, 2014 | Brother XL-6562 Mechanical Sewing Machine
Need to install memory on a veriton Z290G desktop but dont know how to open the computer
1 Turn off your computer and all the peripherals connected to it before
opening it. Then unplug all cables from the power outlets.
2 Place your computer on a flat, steady surface. If your computer is in the
vertical position, rotate the plastic stabilizers and lay your computer on its
side.
3 Turn the screws counterclockwise to release the cover.
4 Hold the sides of the cover with both hands.
5 Slide it back about an inch and then gently lift it upward to detach it.
6 Remove the side panel.
7 Locate the memory DIMM socket on the mainboard.
8 Press the holding clips on both sides of the memory DIMM socket outward
to release the memory DIMM (a). Gently pull the memory DIMM out of the
socket (b).
9 Align the memory DIMM with the socket. Press the memory DIMM into
the socket until the clips lock onto the memory DIMM.
The memory DIMM sockets are slotted to ensure proper
installation. If you insert a memory DIMM but it does not fit easily
into the socket, turn the memory DIMM around and try to insert it
again.
10 Align the cover's hinges to the housing frame; then gently push it in to
slide it back into place.
11 Secure the cover with the screws.
Oct 03, 2011 | Acer Veriton Z290G 185 320GB
1998 ford f 150 and the pointer is off
I take it you mean the gear shift indicator. under the steering column you will find a wire attached to a hook. That is attached ta black thumb wheel on a white holder. just roll the adustment till the indicator lines up in all gears. Most times though the thumb wheel holder is broken and you can not adust correctly. You will have to use a 5.5 mm socket to remove thumb wheel and Remove trim around cluster should be 3, 7mm screws and then 4, 7mm screws holding in cluster. Remove indicator by pushing back the black tabs on each side of indicator at same time and pulling down, then reverse in install indicator
May 18, 2011 | Ford F-150 Cars & Trucks
I have an Elna Carina Electonic machine. It was just tuned up, but got jammed up in the bobbin. I took it out, used brush to get all lint out but now cannot get the bobbin unit back in an working. No...
Lovely machine, don't dispair. You need to turn the rotary hook with your flywheel so that the open side of the hook is facing you. Now move the black inner piece around inside so that the cutout side is facing you too and just a bit to the left. Now lower the bobbin holder in with the metal arms facing towards you , they should slip in between the outer parts. You want the two bobbin case screws to line up with the holes underneath, just give it a bit of a wiggle until you feel it drop into place. Now screw in the two screws on the bobbin holder with your mini screwdriver from your kit to secure.
Now rotate the flywheel towards you, the bobbin holder should stay still while the rotary hook goes around.
If you have any issues feel free to email me on cwrogers@tpg.com.au and I'll try to elaborate or take a pic of the process tonight.
And remember to hold the two threads when you start a seam at the back for a few stitches to avoid the thread jams, just a quirk on these machines but I love them so much.
Hope this helps you.
Mar 16, 2011 | Sewing Machines
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
Sep 06, 2010 | LG FLATRON L1950B-SF 19" LCD Monitor
Brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Jun 24, 2009 | Brother XL-5130 Mechanical Sewing Machine
High brake light
if you pull on each side of the plastic cover covering light it may seem tight but will un-clip so persevere. You will then see how it clips onto two posts. Once removed the bulb is in a holder in center of lamp this holder is bayonet fitting ie turn holder anti c/wise and pull out. The actual bulb is what is known as cap-less (it just pushes in and pulls out ) now you request the correct bulb which is 12volt -18watt do not fit any higher wattage as it will melt. Lamp lens bulbs can be obtained from most motor stores.
Feb 22, 2009 | 2006 Hyundai Sonata
Screen blacking in and out
Hi Esdee, Don't be too surprised if the monitor is having problems. The fact that it does the same thing on another PC is pretty good proof that is in fact the monitor. As far as what is going on the green power LED going on and off in conjunction with the blackouts indicates a power problem to me. - Does wiggling the power cords, plugs cause any change? - When the screen blacks out shine a flashlight on the screen and look to see if you can see any faint images. If you do then you have a backlight problem. If none of this works any further troubleshooting really requires some experience working around electronics and high voltage. Let us know how you want to proceed, as as always please don't forget to rate this posting.
Feb 05, 2007 | BenQ FP567s 15" LCD Monitor
Sunny Health & Fitness 3 in 1 Vibration Trainer Logo
19 people viewed this question
Top Sunny Health & Fitness Office Equipment & Supplies Experts
Kathryn Boyce
Kathryn Boyce
Level 1 Expert
Are you a Sunny Health & Fitness Office Equipment and Supply Expert? Answer questions, earn points and help others
