Question about First Act Music
Crack in electric guitar body
A guy gave me some cash, a ME301 electric guitar made by First Act and a little 10W Dinosaur amplifier for some RC airplane equipment I wanted to sell. I was doing a setup on the guitar (which was a mess) and discovered a crack right up by the neck pocket that is about 4-5 inches long on one side and 3/4 inch on the other side. Once I did a setup with some new strings and all, I was amazed at how well it played for a cheap guitar. No matter if I keep it, or sell it, I need to address that crack. A good crack repair would accomplish 2 things. strengthen that part of the guitar, and make the crack invisible. I could drop in 2 wood screws (countersunk) putty in the screw heads and sand down. But how do I match the paint? it's black. What type of paint should I use etc. etc.
    Top Expert:
  • First Act Master
  • 3,130 Answers
Frankly, given the value of a first act guitar, I wouldn't br investing the time and effort into it.,
That said, I wouldn't try to fadeThe proper paint will be available from Stewart MacDonald guitar parts, in matching paint, but would repaint the entire guitar.
Posted on Mar 22, 2017
  • 6 Answers
SOURCE: strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Posted on Nov 15, 2008
  • 6 Answers
SOURCE: Guitar strings on a mandolin.
By now you may have solved this problem, but maybe this information is still helpful:
What you are essentially recreating is a tenor guitar. Many companies make tenor guitar strings. I would suggest D'Addario J66 80/20 Bronze Tenor Guitar Strings (10-32). I've done this a few times and it is quite fun and makes for an interesting travel guitar.
Have a blast!
Posted on Jan 09, 2009
SOURCE: need help putting my guitar together
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Posted on Jan 10, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: set neck...not enjoying being set anymore.
This sometimes happens on older set neck guitars. Chances are its due to the guitar being exposed to fast changing temperatures or humidity. Since the paint is strictly cosmetic, and no one will see it, I'd leave it alone. If it was an American PRS it may be different but I would not worry about it, just be careful when taking the guitar out in cold and hot weather...and let the case adjust with the guitar in it for about 15 minutes before taking it out.
Posted on Jun 18, 2009
  • 5603 Answers
SOURCE: I need to replace a broken string on my Washburn
Try this site:
http://www.frets.com/fretspages/Musician/Guitar/Setup/SteelStrings/Stringing/ststringing1.html
Posted on Dec 28, 2009
How to take the hum out of an amplifier
We would need more info to help you, but assuming you mean the amp hums with nothing plugged into it, you may need the caps replaced. This is not user serviceable and needs to go to the shop.
Oct 03, 2016 | The Music
What is causing my 1967 Hagstrom II guitar pickups to have an RF interference hum and how can I eliminate it?
I would say your first impression was correct, even though the additional image you submitted is impossible to view clearly. Single coil pickups are particularly vulnerable to 60 Hz EMI (50 Hz in some parts of the world) from AC power lines, and depending on the values and lengths of connecting wires can be surprisingly good antennas for broadcast radio stations or CB transmissions 8^0. This is managed with proper shielding around the electronics cavity in the guitar body, and sometimes, particularly in North America, by connecting the the ground side of the audio circuit to the bridge, which then connects the ground to the strings and then the human body through the hands, allowing it to act as an impedance sink. Best practice has all wires carrying audio signal surrounded by a mesh shield connected to a common point audio ground.
Aug 23, 2017 | Hagstrom Viking II UltraLux Electric...
Guitar amplifier schematics
Wires? Speaker wires? AC cord? PLEASE PEOPLE! Take an extra 10 seconds and be more specific in your descriptions of the problem.
May 22, 2014 | First Act Electric Guitar with Amp - Black...
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
Where is V193037
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
D10sce will not work when plugged into the amp. the cord is nine ( works with my electric.) battery is new. when you turn up the volume on the controll, you can hear it in the amp, just no pick up sound.t
SUBSTITUTE Change the guitar for a friends to see if the amp is really OK. Try your guitar in a friends amp to see if the guitar is OK If the guitar is at fault its either the battery, the connection cord, the little pre amp in the guitar body (you can't fix that) or you have put nylon strings on the guitar which needs stell strings for the pickup to work. Good luck
Feb 13, 2011 | Washburn WD10SCE Cutaway Acoustic-Electric...
My Line 6 Spider II 210 won't make any sound from the guitar. When the amp powers on, the speakers pop a little so I know they are connected right. All of the lights are on and the channels can switch...
Bad soldering, especially around the jacks and plugs. Crack in the circuit board. Bad switch contacts on the headphone jack... all these are first things to check.
Here is your service manual for the unit:
http://elektrotanya.com/line6_spider_15w_ii3012_1508_sm.pdf/download.html
Jan 14, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
I have my first ever electric guitar with a kustom dart 10 amp. I understand that the amp has to be plugged in to the mains through a power cord, but the kustom dart 10 brings none. Is this normal.?
No, there is a cord. OFTEN the cord is buried in cavities in the plastic foam or in cavities in cardboard like spacers in the original box. For some small amps the cord is permanently attached and is coiled up in cavity behind the speaker.
Jan 06, 2011 | Kustom Dart10FXA 10W Guitar Combo...
From the jack plug, what is the black wire attached to in the body of the guitar
That is LIKELY a ground wire. Often it will attach by some means to conductive paint in the cavity of the guitar to act as shielding to reduce hum. Sometimes it is soldered to the back of a pot.
Search this site for a configuration matching your guitar for schematic.
http://www.guitarelectronics.com/c=WdFPr9QORFrwx9ORFVwTPM96v/category/wiring_resources_guitar_wiring_diagrams/
Oct 09, 2010 | Fender American Standard Jazz Bass®...
Fender Hot Rod Deluxe problem. Only one 6L6 glows, swapped tubes, left-hand one still no glow. Brittle, bad sound. Just a player, not an amp guy! Thanks.
This sounds like a bad solder joint or cracked circuit board feeding the heater voltlaage to the left tube.
Pins 2 and 7 are the heater. LOOK for circuit board crack or bad solder to these pins.
Remember there is HIGH VOLTAGE in this unit so use ALL precautions for your personal safety as the voltages can be lethal.
Aug 02, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
35 people viewed this question
Top First Act Music Experts
Michial Gueffroy
Are you a First Act Music Expert? Answer questions, earn points and help others
