Ventless propane heater
Stove will not light on auto with thermostat on, it will light on manual. Shuts off when I turn it back on auto.
SOURCE: vs24pr ventless propane heater
it could be safety feature because of too much carbon dioxide in the room.
ventilate the room and you wont have the problem.
Posted on Dec 15, 2008
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
hiltonjug
  • 612 Answers
SOURCE: I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Posted on Oct 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Rinnai Tropic ventless propane heater. I
The thing with these is over the summer months when they are not in use they get dust inside the ODS safety pilot. When that dust gets in there it cuts down on the oxygen inside and the safety simply shuts down because it was designed to do that. What you need to do is flush the pilot and allow it to dry. I use a product caller but you could use shop air or even a soda straw to blow out the pilot. I used to sell these thermocouples for ODS systems and they are not cheap. Most times they do not solve the problem either because the pilot is dusty. A brand new one won't solve your problem and a cheaper thermocouple don't work on these. More HERE
Here is the whole thing for $52 not a bad price
The thermacouple alone for these cost nearly as much by itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 24, 2010
  • 4736 Answers
SOURCE: ventlessreplaced fanblade /cutwires to motor
I wish you hadn't cut the wires. In any event, it sounds as if you have wired it in reverse. Don't use electrical tape to splice the wires, they may overheat. Use small wire nuts or Heat Shrink Tubing.
For more info check the Installation Manual that came with the blower.
Also, the Model # you listed ... is that for the Comfort Glow heater of the Blower? Or is it the Serial # for the heater?
Unless, it's a super old DESA heater, it doesn't match anything I have.
Thanks,
Rich
Posted on Feb 09, 2011
Testimonial: "reversed conection at temp switch helped adjusted themacouuple closer toflame fixed problem when fan cameon it pulled flame from tip of thermocouple "
Ventless wall heater shuts off during operation
Sounds like thermostat may have a battery going bad as to not supply sufficient power to turn on the relays. As safety procaution when a signal is weak or no longer detected the heater shuts down.
Nov 16, 2017 | Procom Heating & Cooling
Propane ventless wall heater pilot light is to big
You have the correct pressure equaliser on the propane bottle giving the correct pressure.
  1. The minimum gas supply pressure must be 1" water column (249 pa) above the manifold pressure printed on the appliance data plate
  2. The maximum gas supply pressure must not exceed 14" water column (3487 pa or 34.9 Millibars)
Feb 10, 2018 | Heating & Cooling
I have a Rinnai Tropic ventless propane heater. I can light the pilot and turn on the burners. However, when thermostat kicks off the burners...then my pilot goes out and I have to start all over. I...
Dec 24, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Propane tank was almost empty and when the heater/stove came on, it sounded like air coming in. It made a lot of noise, hissing like. Tank full now and occassionally when the heater lights, there's a big...
First of all you need to give more details with your questions.... is this an atmospheric burner, a ventless, a direct vent or a high efficiency. Since you haven't put this down, I will guess that it is an atmospheric (those who know little about propane always go with the cheapest option) As for your problems....The two are totally unrelated. Check your air gas mixture. it sounds like you need to adjust your burner venturi sleeve.
David Lawrence the Propane Furnace Dude
Dec 09, 2009 | Reddy Heater RLP100 Portable Forced Air...
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Pilotlight will not light, getting spark, but no propane.
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Propane was turned off for unrelated problem propane turned back on stove will not lite
If your stove has a standing pilot, it will need to be re-lit.
If this does not help, state the model of your stove.
Apr 28, 2009 | Kitchen Ranges
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
