Question about Shop Fox W1713 16-inch Variable Speed Scroll Saw
Cannot replace motor on scroll saw
Trouble removing old motor from control cover
  • Martin James
    Martin James Mar 29, 2014
    the front plastic cover won't come off so I can disconnect the motor
  • Martin James
    Do you just replace the core of the motor in the old housing?
    Sergeant:
  • 468 Answers
I never tried changing motor but have you contacted a Technical Rep already? or looked on the manual?
Posted on Apr 22, 2014
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
Parts diagram delta fretsaw
Do you see smoke on the motor? Or it just gets hot? How old is your motor? I had same problem with my bandsaw before. The motor was too hot every after use. I opened the motor , cleaned it up. It helped but after a week, it happened again. So I decided to buy new motor.
Jul 07, 2014 | Saws
How to install;drive belt on model 34-670 saw ?
You must lower the motor down as far as possible and then tilt the saw blade so the back end of the motor where the belt is housed is exposed and accessible as possible. Then remove the cover housing at the back end of the motor. This will expose the belt. Thenyou can remove the old belt and install the new one.
May 19, 2014 | Saws
Parts listing for Dremel model 1672 scrollsaw
You can go to a site like www.ereplacementparts.com/ and get a good exploded view and parts list of your tool. It is a very old model and not many parts are available for it anymore.
Oct 27, 2012 | Dremel Model 1672 16" Scroll Saw Owners &...
Change blade
all chain saws have a sprocket that the chain runs on this sprocket is what make the chain rotate on the bar. the bar is the long part that sticks out in front of the motor. you must remove the side cover of the saw to access the sprocket region of the saw. be sure the saw is unplugged and then remove side cover the bar is usually held in place by a couple of bolts. on gas saws these two bolts also hold the side cover in place and must be removed to replace the bar and chain. once you have removed the side cover look for bolts holding the bar in place. if you only want to change the chain then you may be able to only loosen the bolts or screws holding the bar in place.there should be a screw to adjust the bar forwards and backwards. this screw put tension on the chain so when you put a new chain on turning the screw will proberly tension the chain /do not overtighten the chain.
also be sure you put the new chain and blade on the same as the old one that comes off trying to cut with a chain that is on backward does not work. last note if you are replacing the blade because the old one is dull take the saw to a saw shop they can sharpen the exsisting chain and save you money.
Jan 24, 2011 | Remington Electric Chain Saw
My Dewalt DW788 scroll saw continuously ends up speeding up and then slowing down, like the circuit board controller is blown...........the service center says they fixed it and replaced the board and...
Part is $84.00 Are the operators crowding the tool, blades sharp? Scroll saws do not cut quickly.
https://www.ereplacementparts.com/dewalt-dw788-type-scroll-saw-parts-c-1009_2631_2632.html
May 17, 2017 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Changing control switch
Sorry, but that is not going to work ,that motor is not compatible with that type switch. you would need a variable speed motor.Newer models have many more improvements, you should try one of them,much smoother cut. Good luck and please don't forget to rate this answer.Thanks.
Mar 29, 2009 | Saws
Ryobi Scroll Saw runs at maximum speed
Unfortunatly the speed controls cannot be repaired, they can only be replaced. You will have to find a Ryobi dealer in your area and get a new speed controler.
Mar 01, 2009 | Saws
Rigid table saw
You need to look on your motor casing and see what the rating is in terms of voltage, expressed as V., RPM, or revolutions per minute, and horsepower. If you have a 110-115 V one-third or one-half horsepower motor, which is what most Craftsman motors are, it should be easy to find a replacement and take the old one off and replace it with a new one. I will check back and see if this helps.
dcm
Sep 25, 2008 | Saws
Shop Fox W1713 16-inch Variable Speed Scroll Saw Logo
62 people viewed this question
Top Shop Fox Saws Experts
Tom Chichester
ray gallant
Are you a Shop Fox Saw Expert? Answer questions, earn points and help others
