Question about Garden
John Deere G110 electrical problem
I have two black wires jointed together with a female electric connector. the two are joined to three other black wires, one which appears to be grounded with the ground cable from the battery. All said, I can not see where or what to plug the electric fitting into.
  • 57 Answers
Does your mower still work? It is possible this is a connector for an external trickle charger which may be connected while the mower is in longer term storage.
Posted on Mar 30, 2014
Testimonial: "the hour meter does not come on but everything else works.I keep coming back to the thought that these black wires are a series of wires meant to ground things (?). everything on the dash (even the hour meter) has wires connected to them so that is a dead end"
  • woodhenge Mar 31, 2014
    I come back to my original assertion. It is possible that it is a plug for an external trickle charger for when the mower is in storage or otherwise not in use.
  • 4 Answers
SOURCE: 4020 w/ 24v system sparks when the battery is connected
I usually fix electrical problems by process of elimination. Disconnect the wires attached to generator and touch the battery cable to the battery if it still arcs disconnect the regulator. continue until you find whats pulling current from the battery.
Posted on Jun 05, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: John deere x320 will not syart. if one coil ground
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Posted on Dec 23, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
Why does my cat act like its missing when i only turn on my heater/lights anything elec. when these things are off it runs great
The circuit that powers the fuel pump, ignition etc may have a bad connection in the wiring harness where the plugs come together. When extra electrical loads are being fed current through the plug connection there is voltage loss at the plug joint. Thy unplugging the multipoint connector where the wiring harnesses join together around the fusible links etc. You will be able to recognize the culprit by its discoloration due to overheating in the plug. Replacing connector pins and plug clips should take care of it.
Jul 30, 2014 | 1993 Mercury Topaz
Mower won't stay running it stops when you make a
We have a John Deere riding mower and this happens every once and a while. It turns out to be a problem in the wiring connection next to the battery, I have to wiggle the 2 plug in connectors, 1 male 1 female and then ot starts. The larger wire that powers the machine to the key picks up battery acid corrosion every year. A design flaw. wrap with electrical tape but not so tight you will damage the wires, clean both ends with electrical cleaner then you may or may not use a light corrosion spray before reconnection...and wrapping...
Jun 05, 2013 | Garden
My 316 john deere alternator is not charging the bat. Where can I get a electrical dia. to trouble shoot. Bob
there are three wires at the regulator two from the alternator and one that goes to the battery see if there is voltage at the two from the alternator if so the regulator is bad
Sep 11, 2012 | John Deere 300 / 316 Hydrostatic Tractors...
Why does my john deere g110 blows fuse when blades are engaged
unplug the clutch and see try it if the fuse doesn't blow then look at the wires going to the clutch make sure they didn't rub on something
Jun 09, 2012 | John Deere Garden
How do you wire the foot pedal. john deere gator hpx all the wires are off
red white then blue, the blue and white wires are the two that are closest together
Aug 24, 2011 | Peg Perego John Deere Gator HPX
I'm building and attaching a John Deere electric spreader to a x540 tractor. The problem is the wiring. The instruction manual says to connect the wire (which I just attached to the battery terminals) to...
I just purchased the electric spreader model LP3301 for my X500 & ran into the same problem. Here is what I did.
In my ignition wiring harness there are 3 yellow wires, two red, & one purple wire. I took a volt meter & tested the wires with the ignition on & off. The three yellow wires were the hot ones. There are 2 together & 1 alone. I spliced into one of the 2 that are together. The one that is alone is for the lights & is only hot when the lights are on. Electric spreader works only when the ignition is in the on position as it should.
Hope this helps.
Terry
Apr 17, 2011 | John Deere Garden
My son pulled the gas peddle off and there are three wires to reattach. In which order do they go?
there should be two that are close together and a stand alone....the stand alone is red, middle white and then blue
Nov 10, 2010 | Peg Perego John Deere Gator HPX Ride on...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
