Question about Dell Dimension 8300 PC Desktop
Dell Dimension 8300 Windows XP won't boot, just blank screen
Hello, my computer is not booting up and the screen is black. I can hear the fans and I believe the hard drive running but it won't go into the splash screen or show that it is doing anything. I'm semi-tech savvy but I'm not sure where to start looking for the problem. Any advice would be greatly appreciated
  • Mysh68 Jun 15, 2009
    Okay, I did that and it booted up and told me I needed to press the F2 key to fix the time and date. While I was doing that, the screen went blank. Moving the mouse or pressing the keyboard did not bring it back. I did not hear anything shut off. The screen just went blank. Please advise. Thanks!
  • Dell Master
  • 4,806 Answers
Start by taking the motherboard battery out for a minute and cleaning and reseating the ram (memory), then try to reboot.
Post back foe more advice if needed.
Good luck
Posted on Jun 15, 2009
  • Lee Hodgson
    Lee Hodgson Jun 15, 2009
    Get a clean, soft, dry paintbrush, take out the system ram and clean the contacts, also clean the slots on the motherboard and make sure its free of dust.
    If you have more than 1 stick of ram reseat them one by one booting each time you do that as it sounds like a memory issue.
    Please post back
    Scholar:
  • 89 Answers
You should determine the exact component that is causing the issue of a black screen. For this, restart the computer first in Safe Mode. Before troubleshooting, first take a backup of all the system files. Then determine which component is causing the problem. Find the extent of the damage caused by this problem. Then measures should be adopted to solve the issue. If the issue cannot be solved by you alone, then dell customer care should be contacted.
Posted on Sep 29, 2011
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
Mar 13, 2011 | Dell Dimension 8300 PC Desktop
Dimension 8300 boots up to a black screen that says "Alert! Storage battery voltage low" Press f1 to continue, f2 to enter set up etc If I press f2 I can use the keyboard to scroll through...
i think storage battery low indicates that the cmos battery is losing its ability to reatin a charge. try replacing it. if that doesn't solve your problem, you have deeper issues. consult a professional if this is the case.
Jan 31, 2011 | Dell Dimension 8300 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
I would like to reboot my dell dimension 8300
1.Press Start> ShutDown> Restart and OK. It will power down and restart (reboot).
If you cannot do that (for wathever reason), press the Power Down button for about 10 seconds. The computer will turn off. After that you will be able to turn it back on again.
Hope it helps
Aug 22, 2009 | Dell Dimension 8300 PC Desktop
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension Startup
try going into your BIOS and changing the boot sequence, it may be set to boot from floppy instead of harddrive. or you could just reinstall windows, but that sucks cuz then you lose all your data and programs. and not to be rude, but you shouldnt have bought a dell, they are full of problems.
May 11, 2009 | Dell Dimension 3100 PC Desktop
I turn my computer off and back on i hear the music but i get a black screen
Try and do a XP repair: Boot the PC with a Win XP cd.
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 18, 2008 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Booting up windows xp pro on dimension 4700
hmmm..not too happy..sounds like your video card is not too good...try it in safe mode(F8) and then check the video card in control panel, then system, then device manager. make sure driver is clean.
got backup?
Feb 19, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 8300 PC Desktop Logo
758 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
