Question about Measuring Tools & Sensors
My briggs and stration 20 hp ohv /c engine will not start battery is fine and pull not locked up what could be wrong
  • 32 Answers
SOURCE: seems to be compression locked?
adjust the valves
Posted on Jul 20, 2009
  • 257 Answers
SOURCE: will not start, just back fires
sounds like valves need adjusting
Posted on Sep 01, 2009
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
wilsodfarm
  • 986 Answers
SOURCE: i have a cub cadet lt 1018 18.5 hp briggs &
Im sorry but your motor has went to motor heaven,and most of the tme its cheaper to buy a new motor than it is to repair it and bring it back to life,
Posted on Nov 06, 2009
Dustybobcat
  • 39 Answers
SOURCE: briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Posted on Mar 14, 2010
Replace starter on my 20 hp briggs
check that battery is installed properly,i once got a bad batterie that was wired reverse.and the starter ran in reverse.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton platinum 5.5 hp ohv i/c engine
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
I have a cub cadet lt 1018 18.5 hp briggs &
Nov 06, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Runs fine but battery is dead
it should charge the battery itself ,if you have rnn the engine even for a few seconds without abattery connected you will have burnt out the rectifier under the fly wheel, that will probabley be your main trouble
Aug 15, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Gas line vapor locks on pressure side of fuel pump intec v twin 20 hp
Sounds like you have a hole in the fuelpump diaphram which is pumping air into the line or could be a hole in the line or loose line.
Aug 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
23 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
