Scans back and forth does not stop to pick up record
What do I need to look at first?
    Champion:
    Habit-Forming:
  • 239 Answers
What make and model?
Posted on Aug 09, 2014
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: WON'T pick up record just keeps going back and
You may have a bad circuit to to faulty capacitor which is common now days. Otherwise I recommend cleaning laser lens eye with rubbing alcohol and cotton swab.
Posted on Sep 28, 2009
Sound noise feedback during recording
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Jan 15, 2013 | Computers & Internet
Sharp TU-TV322H failing to make planned recordings
I had this problem aswell! I tried everything but ended up phoneing the help line, when they asked for what frequancies they found out i was picking up different ones form two different stations. I took the ariel out of the back on the freeview box and run a scan for channels (of course it came up with none as the ariel is unpluged but it overwirites and clears the incorect frequencies). Then plug the areil back into the freeview box and run a scan for channels. After doing this i picked up the correct frequencines form the correct station and my recordings actually recorded! If you phone the help line (08444159159) they will tell you what frequencies you should be picking up. I hope this qorkes for you!
Apr 05, 2010 | Sharp TUTV322H
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
WON'T pick up record just keeps going back and forth like in search mode
Sep 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
May 09, 2009 | Audio Players & Recorders
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
47 people viewed this question
 Grubhead
Grubhead
