Question about Hampton Bay 24002 Ceiling Fan
I HAVE 3 HAMPTON BAY FAN. ALL 3 HAVE MAL FUNCTION ON THE MOVEMENTS CONTROLLED BY REMOTE. NEED HELP & ASSISTANCE. CAN TTHE RECEIVER [ IN THE FAN ] & THE REMOTE BE REPLACED IN ORDER TO GET THE PROBLEM RESOLVED. THKS.
  • 2,071 Answers
This symptom is in control panel board circuit where the remote is triggered .The common causes circuit problem is cold solder or loose connection that why the motor of fan funtion abnormally and it cause the motor to overheat and shutdown automatically.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the unit turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough. Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components.You just resolder all component joint parts in the circuit board and better you clean also the machine and lubricate moving joint parts.So it works normally again.
Hope it may helps...
Regards:
VOTIT
Posted on Jun 15, 2009
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Where to buy a universal remote for Hampton Bay ceiling fan w/reverse that's 6 Years old fan?
You can use a remote from Home Depot, where the fan was bought. Reverse will have to be done manually at fan.
Aug 29, 2014 | Hampton Bay 24002 Ceiling Fan
How to reverse remote controlled Hampton Bay fan with no reverse button on remote
There should be a switch on the side of the fan that you can hit that reverses direction.
Jul 14, 2014 | Hampton Bay Dryers
Hampton Bay Sidewinder ceiling fan. For ten years, wall mounted control functioned until it 'blew' when electrician was working on a remodel of another room. Installed another control (Progressive...
You called customer care about a Hampton Bay & they sent you Minka Aire??? Hampton Bay is a store brand for Home Depot. If The fan came with a remote, you probably need the one for your fan.
Aug 24, 2013 | Hampton Bay Sidewinder 04890 Ceiling Fan
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Hampton Bay Ceiling Fan - remote problem
Hello Espanbauer,
KEEP in mind it could be the receiver also
(cheapest & best first guess is the REMOTE).
I get all my REMOTES from eBay...
(Although AMAZON does sell these)
Believe it or not if they are advertised as GENUINE & new
and come from ESTABLISHED sellers... You are well
protected by both eBay & PayPal
ALWAYS pay close attention to SHIPPING COSTS
LOOK here:
Genuine Hampton Bay Ceiling Fan Remote Control UC7078T with Up Down Light...
InTHIS price range
Hope this helps
Carnac the Magnificent
Sep 20, 2017 | Hampton Bay Dryers
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Dec 08, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 24002 Ceiling Fan Logo
52 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
