Question about Gateway Midway Motherboard 4000820, 4000887
32-BIT OR 64-BIT? MOBO 4000820, NO OS
WIPED OS BEFORE THINKING. WANT TO USE LINUX. BUT NEED TO KNOW IF 32-BIT OR 64-BIT.
    Master:
  • 680 Answers
Try 32 bit if it doesn't work then try 64 bit
Terry
Posted on Apr 01, 2014
How do I switch/upgrade my motherboard from a 32bit to a 64bit please
Having a 32-bit or 64-bit operating system mainly depends upon the operating system that is loaded on your primary hard drive (generally drive C:). However, your motherboard's components, i.e., processor and amount of system RAM, will be a major factor in determining whether you can only run a 32-bit operating system, or upgrade to a 64-bit system.
Sep 22, 2014 | Computers & Internet
My device is not being recognized
It looks like Linux Mint is not a supported OS.
Buffalo Americas
Only the following are supported:
Windows 8 (32-bit/64-bit), Windows 7 (32-bit/64-bit), Windows Vista (32-bit/64-bit), Windows XP, Mac OS X 10.5 or later
The Linux Mint Dev Team may be working on a solution, but this is not something Buffalo will help you with.
Feb 11, 2014 | Buffalo Technology MiniStation Computers &...
Am looking for a linux 64bit since my comp has 8 gb ram and 32 bit os wont recognise 8 gb of ram
If you go here, the bottom choice in the PLATFORM drop-down box is 64 bit. There are eleven different 64 bit flavors linked from there.
But the 32 bit Linux kernel can be recompiled to recognize up to 64 Gb of RAM. Please post again if you have more questions, and please rate my solution.
Apr 05, 2009 | Red Hat Enterprise Linux ES Basic Edition
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
RAM utilisation
Can't do it with 32 bit, must install xp64 or vista 64.
Oct 30, 2008 | Computers & Internet
16g RAM on 32 bit mobo?
Well...i never heared of a 16gbram mobo and also no OS is able to support it propery and also u don't need so much memory but whatever.You could use smaller modules like 1gb or 2gb but you must know wht type of memory it uses and also what's the minimum amount of ram that can be used.
Oct 30, 2008 | ASUS P5S800-VM Motherboard
Flash player 9 on suse 10.1
NOTE: Since many proprietary video codecs, flash player etc.. are not available for 64-bit platforms, it is difficult to configure 64-bit machines for a complete multimedia experience. Hence it is advised that users new to linux use the 32-bit version of SUSE (32-bit SUSE works fine on 64-bit AMD machines)
Way to check would be open a terminal
type uname -a
If you use 32-bit Follow this page - http://tweakhound.com/linux/suse/101/installing_1.htm
I use ubuntu and to be able to compile flash you need dependencies to be met.
If you need more help, ask.
G'luck
Oct 30, 2008 | SuSE Linux Enterprise Management Pack...
Install Linux OS
I would recommend installing Linux Mint LXDE, Cinnamon or KDE, which is a free OS available for free download from http://linuxmint.com Cinnamon and KDE are full featured, XFCE is streamlined and slightly faster and a better choice for older computers with less memory and/or storage space. All versions come with Firefox and LibreOffice full Office Suite, capable of saving and reading files in the popular MS Office formats like .doc, .docX, .ppt and xls.
Linux comes with almost everything necessary to begin using the computer immediately after installing the OS.
To install it on a netbook or notebook computer, I'm assuming you don't have a DVD optical drive so you have to install it from a USB thumb drive. If you have a DVD optical drive, I would still recommend installing it from the USB thumb drive, ... it's more reliable and less prone to failures from trying to burn a DVD on old, dirty or out-of tolerance equipment.
First download the .iso file on another computer. If you're not sure if your computer is 32-bit or 64-bit, you can use the 32-bit for both, or try the 64-bit - if that doesn't work, use the 32-bit.
Use a free program to create a bootable USB using the .iso file. (You can't just copy the file to the USB drive) ... I'd recommend using Active ISO Burner from NTFS.com ... here's the download link ... http://www.ntfs.com/iso-burning.htm (You should be using at least an 8 GB size thumb drive).
Once you've created the bootable USB drive from the .iso file, you should be able to insert it and start the computer and see the Linux Mint startup screen. It will come up in LIVE mode, without installing itself, so you can try it out.
If you want to install it, make sure you are connected to the Internet and have your AC power adapter plugged in.
If the computer doesn't come up with the Linux screen, you probably just need to reset your BIOS boot order so it boots from the USB driver first. Plug in the USB drive and start the computer. Look of instructions for set up or boot order, usually pressing F2 while the computer is starting. Follow the directions to move the USB to the top of the boot devices, i.e. about the hard drive. Save changes and restart the computer. It should now boot from the USB. If you have trouble doing this or burning the bootable USB, you might have a geek friend or relative that can help or do it for you.
When the LIVE mode comes up, it displays the Linux desktop with an Install icon. If you double click the Install Icon you will begin the installation process and just follow the simple prompts and create a password when prompted.
Linux never requires anti-virus and does not become infected. You can visit the main http://linuxmint.com website and download the .PDF manual if you are interested.
Your computer is probably 64-bit, but if not, there is also a 32-bit version available for download.
The image shown below is from my Acer and is Linux Mint KDE, which is also available from the same website and similar to LXDE, but more full-featured. All Google programs I know of are available for Linux, since Google uses 100% Linux. Android is Linux also.
Once you install your Linux, you'll want to run the Update Manager to get the latest updates.
On my Acer netbook I have 3 Linux OS's installed. Linux Mint Cinnamon 64-bit, Linux Mint KDE Cinnamon 64-bit and Linux Mint XFCE 64-bit. I select the OS I want at startup when the computer starts.
Oct 04, 2008 | Microsoft Windows Xp Home Edition Sp2...
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
Gateway Midway Motherboard 4000820, 4000887 Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
