Question about Tools & Hardware - Others
Powerfast electric nail gun
I have a Power Fast brad nailer. I'm trying to use 5/8" brads, but it keeps jamming. Don't have the same problem with 1" brads. Is there a fix?
rowdy45176
  • 2176 Answers
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Posted on Feb 21, 2009
SOURCE: cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
Posted on May 05, 2009
  • 59 Answers
SOURCE: will only shoot one brad and then stops
its problem is too much oil or not enough. never the less, it needs taken apart and cleaned and inspected. make sure you are shooting the right guage and brand hardware. generic doesnt always work.
Posted on May 23, 2009
  • 15 Answers
SOURCE: how to remove brads jammed in the nailer
Open the top where the plunger is...remove the jam and push the plunger back..close up the gun and you should be fine. Make sure you disconnect your air hose first!!!
Posted on Jun 08, 2010
  • 1116 Answers
SOURCE: how to load brads into stanley tre 550 electric
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Posted on Jun 20, 2011
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
How to load brads into stanley tre 550 electric staple/brad nail gun
TO LOAD STAPLES
TO LOAD BRADS
TO STAPLE OR NAIL
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
A 1 1/4" brad nail only penetrates 1/2 inch
Hi, There should be a power adjustment on the top of the driving head. Make adjustments there, and the penetration should improve.
--W/D--
Feb 24, 2011 | Arrow ET200 Electric Brad Nail Gun
Shooting 2 nails at a time and then jams
make sure you are using 18 gauge brads in the gun. also if the brads have gotten wet or are old, the paper or wax coating on the becomes weak and it will release more than one nail at a time. try different brads in it.
Dec 15, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Brad nails not in all the way
There are no adjustments on any electric stapler / brad nailer that I've heard of , only the pnumatics. The electric staplers/brad nailers only work well in softer woods
May 26, 2009 | Arrow ET200 Electric Brad Nail Gun
Cant find replacement brads for swingline
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Tools & Hardware - Others Logo
70 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
