Question about Leisure Arts 63 Sampler Stitches To Crochet 63 Sampler Stitches To Crochet
Crochet stitches how to
Do I just skip over them or do I slip stitch over?
Decreasing single crochet stitches
There are several ways of decreasing crochet stitches, but the pattern should indicate what stitches to use. The most common (or easiest) is to yarn over in the first stitch (do NOT pull the rest of the stitch through) and then yarn over into the second stitch and pull the final stitch through both yarn overs.
How to Decrease Single Crochet dummies
Mar 18, 2017 | Sewing Machines
What does "work Puff Stitch, Ch 1" mean?
Usually it is best to perform each step as stated in the pattern. Close the Puff stitch (follow the instructions for closing the Puff stitch), then Chain 1.
Perhaps this will help:
How to Crochet Puff Stitch dummies
Crochet Puff Stitch Slow Motion Crochet
Puff Stitch crochet
Dec 05, 2016 | Sewing Machines
How to perform a front post treble stitch as well as a back post treble stitch
This video will probably help:
Crochet Front Post Treble Crochet FPtrc
To make the stitch on the back of the stitch, you would insert the hook from the back side of the project and work the treble stitch on the back.
How to Crochet Back Post Triple Treble Crochet Stitch
Jul 13, 2016 | Sewing Machines
How do I make a begining cluster stitch in crochet
Hi Carol, you may find that the knitting community www.ravelry.com is helpful to you, lots of free patterns, yarn discussions and information shared between members and its free to join up.
also Youtube is a great source of knitting tutorials, there's several that come up when I searched Cluster Stitch Crochet Cluster Stitch Crochet Guru Stitch Guide
Feb 17, 2015 | HAND Crocheted Crochet Crossed Stitch...
I'm struggling with a knitting pattern how do I tw2 slip next stitch knit 1 pass slip stitch over and then knit into back of knitted stitch I just can't seem to get it right
Skip the first stitch, knit the second stitch normally, do not slip it off, Now turn your work around so you can knit the skipped stitch normally and slip both loops off the left needle.
You start out with 2 stitchs and end up with 2 stitches having knitted , them out of order. This makes a mini -cable , It won't look like much of anything until you have several column of them,then you will start to see the effect better.
Oct 12, 2014 | Crafts & Hobbies
How do I crochet a popcorn stitch
there's a lot of good youtube demos
How to Crochet the Popcorn Stitch (Left-Handed)
http://www.youtube.com/watch?v=7jzXfqbAWak
or #10 How to work a popcorn stitch in crochet tutorial LEFT-HANDED
http://www.youtube.com/watch?v=3Eba4e-GSmw
Apr 18, 2014 | PTAJ Marketing Crocheting Stitches
Skipping crochet stitches in pattern
Ok, so do what it says... put your next stitch in the 81st stitch of the previous row.
HDC=half double crochet.
Mar 14, 2013 | Sewing Machines
Want to change a hand crochet pattern for an afghan and make it alternating rows of two different hand crochet stitches;
After the Shell row... chain 2,skip 1, then begin your double crochet.
May I suggest that you find a crochet forum or video on youtube? Lots of things to learn on Youtube. ;)
Sep 12, 2012 | Sewing Machines
Leisure Arts 63 Sampler Stitches To Crochet 63 Sampler Stitches To Crochet Logo
64 people viewed this question
Top Leisure Arts Home Experts
john h
Tom Chichester
Are you a Leisure Arts Home Expert? Answer questions, earn points and help others
