Question about Frigidaire ATF6700FS Front Load Washer
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
All other lights are working, but when I hit the start button the 'dr' error message comes on. Could it be an alignment problem, or more likely that the door switch needs replacing... or the control board. How do I know which it may be?
  • Official Brand Answer
  • 2,267 Answers
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Posted on Apr 01, 2014
  • 117 Answers
SOURCE: Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Posted on Feb 25, 2009
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
SOURCE: Frigidaire ATFB6000ES1 won't do anything...
My Frigidaire was doing the same thing. I tried holding the Start/Pause buttons, but I didn't get an error code or anything.
So just for the heck of it my husband unplugged it for 5 seconds, then he held down the Option and the Select buttons together and then only the spin light was on so I pushed start and it started. I guess it was stuck on spin.
Good Luck !
Posted on Nov 16, 2007
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Posted on Dec 02, 2009
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Error code 41
The error code E41 means the control board is detecting an open door switch. It might be due to a broken wire harness, broken door lock/switch assembly, or in worst cases a faulty control board.
Unplug the machine or disconnect power. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the spring of the retaining hoop then remove it.
Carefully peel off the part of the door seal from the lip of the door opening near the door lock/switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock/switch assembly
to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock/switch assembly out of the front panel then
disconnect the door switch harness then short circuit the terminals by putting a jumper wire between them.
Put the door lock/switch assembly back into position in the front panel then secure it with the securing screws previously removed.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop. Reconnect power and run a test cycle. Replace the door lock and switch assembly (part #131763202) to address the problem if the washer works fine with the door switch bypassed. If not, replace the control board.
Jul 18, 2011 | Frigidaire ATF6700FS Front Load Washer
F 11 fault
F-11 error code is a communication error between the main control and the motor control. I recommend unplugging the washer and removing the access panels. Then check the electrical connections on the main and motor control boards. After the connections are checked, replace the panels and check the operation. I have added the information on the Fdl error code because it is usually associated with the F11 code.
The FdL fault code indicates that you have a problem with the door lock assembly. This is often caused by a failed door lock but it can also be caused by a failed wiring harness connection or in some instances by a failed control board.
Check for damage to the door hook on the washer door and look for anything that could be clogging the catch on the door lock assembly on the front panel of the washer.
You may need to check the wire harness connections on the door lock assembly. The images below show the procedure for accessing the door lock assembly on this type of washer. Be sure that you unplug the washer before accessing internal components.
I have seen the failure be caused by a door lock and a faulty machine control board. A little trick I have found is to remove the top of the washer and push down lightly on the connector that is labeled dls5 this connector should have four black wires. This connector is located on the machine control board under the top. Use an insulated screwdriver to push on the connector and start a cycle. If the door locks and the washer works, I recommend replacing the machine control. It has a bad solder joint on the board. We often see error code F11 also with bad solder joints on the control board. If pushing on the connector did not make a difference, I would suspect a faulty door lock first.
I hope helps (remember to rate this free answer).
Jun 22, 2011 | Washing Machines
F 11 code flashing
The F-11 error code is a communication error between the main control and the motor control. I recommend unplugging the washer and removing the access panels.
Fdl error code because it is usually associated with the F11 code. The FdL fault code indicates that you have a problem with the door lock assembly. This is often caused by a failed door lock but it can also be caused by a failed wiring harness connection or in some instances by a failed control board.
Hope this helps.
Jun 06, 2011 | Washing Machines
Error f-dl
The door lock and door itself is to be checked.Is the door closing properly or is it remaining open.Check and confirm it.If the door open/close properly then its the door lock latch problem.It has to be checked and replaced.The FdL error code indicates a problem with the door lock assembly on the washer.The control board detects that the washer door is not locking properly. Replacing the door lock assembly will normally fix this problem. It can also be caused by a wire harness connection failure or sometimes by a failed control board.But in most of the cases its faulty door lock.To get the required parts you can get it from.----------- www.repairclinic.com -------- -------------- Keep updated for any further queries.Thanks.
Oct 14, 2010 | Kenmore Elite 45986 Front Load Washer
44082 is the model #
he code "dr" means the control doesn't see the door switch being closed.This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced.
Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem.
The switch can be obtained from the following link: Sears PartsDirect . Remember to unplug the washer first before attempting to change the switch.
The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
I hope this information helps you resolve this problem but submit another question with any additional details for further assistance.
Helpful attachments:
The code "dr" means the control doesn't see the door switch being closed. This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced. Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem. The switch can be obtained from the following link: [Sears PartsDirect |www.searspartsdirect.com] . Remember to unplug the washer first before attempting to change the switch. The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
Apr 15, 2010 | Kenmore 43042 Front Load Washer
What is e47 code mean
The problem is with th door lock assembly or the control board. You can meter the PTC on the door lock assembly to determine if the problem is in the lock or control board. If PTC meters open or closed = bad door lock assembly. 1200 to1500 ohms = bad control board.
Mar 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dr error
DR is a Door open error .. you may have a faulity door lock.. first try to see if it is not closing right.. If all closes good the door lock is not to hard to replace... let me know what you find out?
Aug 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Open Questions:
See all Frigidaire ATF6700FS Front Load Washer Questions
Frigidaire ATF6700FS Front Load Washer Logo
111 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
