Question about Lafer Billie Ergonomic Recliner Chair"
Reclining back adjustments
The reclining back does not lock in a selected position ands keeps slipping when weight is applied
Seat wont stay upright, now keeps reclining
Hi Sam,
We would recommend you contact Silver Cross directly for assistance
Feb 06, 2014 | Silver Cross POP Jet Umbrella Stroller
Chrysler Pacifica 2006 driver reclining seat won't work just stopped. All other functions work ok
If you look under the seat, you will find several motors. For reclining there could be a few of options to check. Motor being one, and linkage being one, and just wear and tear on the swivel points. Hate to say this, but weight of the person can make a big difference on all I mentioned.
Jul 12, 2013 | Cars & Trucks
The spring snapped on lafer recliner chair
I bought replacement spring at Lowes
This was Hillman brand replacement spring
Five eight x three and a quarter x 072 inch type
2 springs per pkg works great
Apr 06, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
Rear seat on 2003 outlander is stuck in the down position how do i get it to the up position?
http://outlander.net.ru/Vitaly/CHASSIS/03/all_of_car.pdf
I have the same problem. Finally found this repair manual on line.
Pages 52A-27 & 28 give a break down of the seat.
The reclining knob is broken #23. It engages the reclining cable #31.
Look closely at the underside of the knob to see if part of it is broken off and this will indicate we share the same problem.
I've always let go off the knob when reclining the seat, but in the future, I'll be slowly releasing it.
Mar 13, 2011 | 2003 Mitsubishi Outlander
How do i remove the front seats of a 1998 Pontiac Grand Prix?
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
Sep 01, 2009 | 1998 Pontiac Grand Prix
How to change reclining position
Viewed from behind, there are two cords with pull tbs that are gathered together in the center of the seatback with a black plastic gather. These two cords are loosen or tightened to raise or lower the seat back recline position.
Mar 01, 2009 | Graco MetroLite Air 6116 Stroller
Drivers side seat not working properly
hi this sounds like the coiled spring that is enclosed behind the cover where the recline lever is it has either broken or the pin it locates on has snapped or spring has for some reason slipped its fastening ? try removing cover and investigate the spring and its locator points
Dec 29, 2008 | 2006 Hyundai Sonata
Passenger side seat reclining device
check the adjusting bar on the pass. door side of seat.
May 20, 2008 | 2001 Chevrolet Monte Carlo
Lafer Billie Ergonomic Recliner Chair" Logo
94 people viewed this question
Top Lafer Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Lafer Furniture Expert? Answer questions, earn points and help others
