Question about Lafer Billie Ergonomic Recliner Chair"
The reclining back won't lock in any position
Th positioning lock slips
Bmw 3 series 1996 Upolsterer had seat back off & now wont lock in upright possision
The gears for the recliner has been misaligned/broken. Disassemble and look for broken parts. Refer to service manual to realign,
Jul 20, 2014 | 1996 BMW 3 Series
1990 Park Ave drivers seat recliner motor
You must remove the motor, move the seat to the desired position and then reinstall the motor to lock the seat in the position.
Sep 10, 2012 | Cars & Trucks
HONDA ACCORD Seats Front Assembly Recliner went down and won't go up
I wouldn't ruin anything by trying things yourself
I would have a dealer check it out
The dealer I used in the past, has a seat specialist come
in on Wed only, around 5:30 after the service bays close
& one service writer hangs out until that person fixes a
couple vehicles seat issues
Jun 12, 2012 | 1995 Honda Accord
Front seats recliners won't "click" in the upright position.
personally i would pull the seats and weld them into a position that is comfortable both sides of the seat should be welded. a small mig welder would take care of this issue nicely and permanently ! .. jay Florida
Nov 10, 2011 | 1986 Chevrolet Camaro
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Drivers side seat not working properly
hi this sounds like the coiled spring that is enclosed behind the cover where the recline lever is it has either broken or the pin it locates on has snapped or spring has for some reason slipped its fastening ? try removing cover and investigate the spring and its locator points
Dec 29, 2008 | 2006 Hyundai Sonata
Front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Jul 22, 2008 | 2000 Ford Focus
Lafer Billie Ergonomic Recliner Chair" Logo
107 people viewed this question
Top Lafer Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Lafer Furniture Expert? Answer questions, earn points and help others
