Question about Ryobi 22 in. 26 cc Gas Hedge Trimmer RY39500
Will not stay running
Motor quits when turned torun
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
How dose it run with choke on Half? I would try adjusting adjusting air fuel mixture, but make sure you have clean air filter in it before any thing else.
Posted on Apr 13, 2014
Why wont it run?
Is the motor running? If not, is it receiving power? Is the belt slipping? If motor has brushes, they might need replacement.
Nov 18, 2015 | Nordic Track APEX 6100XI TREADMILL Console
Why won't my rider move and keep running?
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
Jul 21, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Very small 2 strokes need lots of compression,so keep the oil mix high,even as low as 22 to 1,should be 25 to 1,but take care mixing.scrape out all the oil and mix thoroughly.Each pull of the rope should be quite hard,and you should really feel each compression.if motor keeps on turning by itself after you've stopped pulling,it means compression poor,replace barrel,piston
Jul 24, 2014 | Poulan Pro 1129478 Weed Eater 952711557 0...
Motor quits when pull trigger
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Jul 13, 2013 | Campbell Hausfeld PW2102 Gas Pressure...
I have a 1997 acura cl 3.0 everytime i turn off my car the cooling fan stays on for quite awhile
The cooling fan is controlled by a heat sensor and operates independently of the motor. When you turn off your Acura, the cooling fan continues to run until the sensor determines the tempurature has decreased enough to turn off the fan
Dec 24, 2012 | 1998 Acura CL
Dryer cuts out after about 3-5 min of use, removed vent pipe from dryer and still same results.
The only thing that would make it quit would be the motor overload. If it was the fuse the dryer would die and stay dead till you replaced it. heater limits go out she gonna still run. It has to be the motor overload. Reach inside and turn the drum by hand. If it turns easy then your motor is probably overheating. Sometimes you can get a little more life outta that motor. HERE IS HOW
Dec 20, 2010 | Roper REX4634KQ Electric Dryer
Fist of all the ignition switch tuns with out key its been laid up seveveral years.had to jump solinoid to get engine to run .so i replaed solinoid nowwhen you turn the key nothing happens youneed to jump...
As the car has been laid up many years, it needs a thorough servicing. Besides a solenoid in the starter motor, there is a bendex as well. Its role is to push the starter pinion forwards to enable it to engage the flywheel when you turn the key. And when the key is turned backwards then this pinion is pulled backwards. This goes bad sometimes as most of the things do. So it should be repaired. Then the starter motor will start functioning as it should.
Oct 14, 2010 | Ford Ranger Cars & Trucks
Ignition tumbler removal
There is a metal button on the ignition housing. Insert your key press the button while turning the key until the button goes in pull out the tumbler. Let me know if the helps. You need more help I will sent you step by step instructions. Hope that helped u out.
Jul 01, 2009 | 1997 Jeep Tj
2001 Pt Cruiser Quit
could be a bad alternator or battery, if by "the motor turns over somewhat" it sounds like it tries to turn over less and less each time you try. Even if it did start it wouldn't stay running with one of these problems.
May 20, 2009 | 2001 Chrysler PT Cruiser
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Ryobi 22 in. 26 cc Gas Hedge Trimmer RY39500 Logo
114 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
