Question about Samsung RF263BEAEBC Black Pearl 26 cu. ft. French Door Refrigerator
SAMSUNG RF263beaebc..Ice maker is leaking water into ice bucket, causing block ice and auger failure. Cracked one ice bucket already!
Ice cicles forming under ice maker. Water in ice bucket(frozen).
2 Suggested Answers
fourtdollarm
  • 11 Answers
SOURCE: samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
Posted on Aug 19, 2012
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
Where is the ice maker reset button on a Samsung RS265TDRS?
This ice maker is on the door, so
remove ice bucket
move your fingers up under the ice maker tray guard on the left side until you find a button
you may have to press this several times, perhaps hold down firmly until you see some action
then quickly replace bucket & close door
Sep 06, 2013 | Samsung RS265TDRS 25.5CuFt Side-by-Side...
When the room is full stop making ice , the problem is leaking water with rush from the ice maker
Good day,
don't understand your question at all. When room is full. Full of what ??
But for know, I'll include a step by step procedure for repairing ice makers. Any further questions, please just ask..
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Mar 31, 2010 | Freezers
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
My ice maker stop working
Knowing how an ice maker works can greatly increase your ability to diagnose and repair it. Just like vehicles, ice makers all may look different but they all work on the same princible. A thermostat starts the ball rolling, turning on a motor and a heater to loosen the ice, as the ice dumps a trigger fires up the water valve and refills it. The whole thing comes to a halt and waits till the thermostat gets satisfied once again.
So what can go wrong? The ice maker will give a clue. If their is ice in the ice maker but none in the bucket that is an ice maker failure. If the ice mold is empty and no ice in the bucket then the water valve is bad.
One thing you can do is get a bottle of water and fill the mold. If it kicks out a batch but no more, water valve replacement needed. If it don't then ice maker problem. If you have shelling or fouled cubes, look for dirty coils below the ice box that make for faulty cooling. Ice forms at 32f but ice mold tstats don't kick in the afterburners till 25f. I have some more detailed tips with videos and manuals: HERE
Jan 10, 2010 | Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Samsung RF263BEAEBC Black Pearl 26 cu. ft. French Door Refrigerator Logo
136 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
