Question about Bosch Exxcel WVT3250 Front Load Washer / Dryer
Cleaning Agent where to buy Calc?
Krups ea8010 expresso machine The CALC light comes on when switching on the machine . Then after 1 min it's starts spraying water from the frother . And keep doing that every 1 min. What should I do ?
It seems like it is part way through the descale process, put 500ml of water in the tank and let it run. Once tank is empty after a couple of minutes it may detect nil water and request next part of the process. If not then brain may be scrambled which may involve a trip to authorised service agent.
Mar 17, 2015 | Krups Coffee Makers & Espresso Machines
Need cleaning product for inside washer/dryer
you need Afresh this is the name of the product that is reccomended by Whirlpool
Mar 29, 2014 | Bosch Exxcel WVT 2850 Front Load Washer /...
What do you do when it says calc. on the display?
Calc is indicating that it's time to descale the lime build up inside your coffee maker. Most machines are easily cleaned by running a solution of 4 parts water to 1 part vinegar. Run this solution through a regular coffee cycle (no coffee). After running this solution, you may want to run straight water once more to ensure there's no vinegar aftertaste. Your machine will now be clean and the CALC message should disappear. If not, post back with the Model # of your Krups coffee maker for further instructions. Some machines have a Descale or Self Cleaning option built into them.
Apr 24, 2011 | Krups Coffee Makers & Espresso Machines
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Where do you put the calc pill?...how does it open? what are those long white pieces that come in a package about 6-7 inches? and with them, a box with something 'poison' on it? IT NEEDS TO BE...
The long white piece is a water filter. It filters calc (lime) out of the water. It should fit in the water container at the back. Just click it in.
The cleaning pills are not for de-scaling. You should run the cleaning program. To do this open the small lid at the top of the machine, press the P-button until the screen changes (a few seconds). Turn the dial until service is in the screen push the dial and turn until cleaning appears. Push the dial button again.The pill should be put in the coffee powder entrance. If you start the cleaning program it will state when you should do that.
Oct 06, 2010 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Instructions for calc n clean HAVE TODAY
Hi
I too had the same problem. I emailed Bosch (via their website and gave them the model number and they have emailed the instructions.
This should have been with the iron in the first place!
Aug 09, 2010 | Bosch Irons
My Maytag stinks! Literally! It smells like mold or a cesspool. What could be causing this? Is there something i should be cleaning that I'm not that could be causing this odor?
This is normally a build up of dirt within drum....You could try boil wash on its own or buy a cleaning agent for that purpose/ also check sink is clean @ drain hose end. this can cause problems..Happy wash days....Good luck
Oct 04, 2009 | Washing Machines
The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Cant get anti calc cartridges for my steam generator
I had to order mine direct from Breville. If you go to their website and contact them with the model of the iron then they will give you details of price and postage.
Aug 25, 2008 | Irons
Open Questions:
See all Bosch Exxcel WVT3250 Front Load Washer / Dryer Questions
Bosch Exxcel WVT3250 Front Load Washer / Dryer Logo
12 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
