Question about Epson Stylus CX9400 Photo Printer
I'm getting light horizontal lines in my printout.
I have cleaned the nozzles at least 10 times in a row, but it doesn't fix the problem. However, when I select "Best Photo", everything looks OK.
    Problem Solver:
  • 10 Answers
A cleaning cycle will clear clogged nozzles, but it sounds like you have actual lint on the printhead. Buy an Epson cleaning kit on Ebay. It will come with a special fluid and a
Posted on Apr 13, 2014
Testimonial: "The answer was only partially complete"
  • oldmansammys
    oldmansammys Apr 14, 2014
    It will come with a special fluid and a foam tipped cleaning wand. It should take care of the problem. Do NOT use a q-tip.
silly girl
  • 513 Answers
SOURCE: yellow ink does not come out.
Its possible that your printer is fooled to think that the yellow ink level is lower than it really is. not uncommon. Have you changed the different carts on different occasions? You should try resetting the printer. I can tell you that the stylus 500 is reset by turning off, then back on while holding down the Load/Eject button, can't say if it will do the trick on your r300. BTW - epson printers do not like refills or generic - they will clog. I ran across the following cleaning method on the web, it might help you: "Follow this procedure AT YOUR OWN RISK for all I know I may have damaged my printer irreparably, but it does not appear so.) With the power off I manually moved the print heads to the left exposing the pad under the color head. I used several cotton swabs to soak up as much old ink from this pad as I could. I then liberally applied rubbing alcohol to the pad with a cotton swab. About three swabs worth, saturating the pad. I manually returned the print head to *exactly* the same position it was originally in. I turned on the power. This activated the cleaning sequence. (You might also want to press the color head cleaning button to make sure that at least one cleaning cycle runs with the alcohol on the pad.) I turned off the power. Then, while holding down the color cleaning button, I turned the power back on. This activates the self test. By the time the printing of the second sheet of the test was half way completed I had all my colors back."
Posted on Apr 23, 2006
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Posted on Oct 25, 2007
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
gwbm
  • 353 Answers
SOURCE: Epson stylus C88 makes black horizontal lines on the print
This "banding" is caused by uneven ink flow through the print nozzles.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no perfect results, are you sure you have good ink cartridges properly installed? The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. To eliminate this possibility, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old ones later if it turns out they DO have ink in them.
If none of the above works, then you may have blocked print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Posted on Apr 08, 2009
  • 11 Answers
SOURCE: Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Posted on Jun 28, 2009
Printing every other line lighter
Use the Canon software to do a "nozzle check".
The print-head has multiple "jets" that spray ink onto consecutive "rows" across the width of the paper. If some of the jets are clogged, then you get the "every other line is lighter" effect, and the printout from the "nozzle check" will show a pattern of "stripes".
May 10, 2014 | Canon PIXMA Office Equipment & Supplies
HP Photosmart C7180 printer with clogged print head.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 30, 2012 | HP Photosmart C7180 All-In-One InkJet...
I have Epson stylus photo 925 and get horizontal lines on printed page. I have run the Print Head Alignment program but the printout is too light to see. Aolution?
Hi
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Please let me know if you need more help.
Mar 05, 2011 | Epson Stylus Photo 925 InkJet Printer
How do I print the nozzle check pattern?
Dear Sir,
plz flow this step for solve your probelm
These are the 2 important features for maintenance of your printer.
Nozzle Check
If your printouts are unexpectedly faint or have some missing dots or lines, it means that certain colour ink does not flow out nicely and consistantly. This is when you need to perform a nozzle check. If your nozzle pattern is good, then, your printouts will be good and nice as well. If your nozzle pattern breaks at certain parts, it means you need to clean the print head. Here's how to perform a nozzle check:
1. Click Start
2. Click Control Panel
3. Click Printers and Faxes
4. Right click your printer icon
5. Click Printing Preference
6. Click Maintenance
7. Click Nozzle Check
8. Click Print
9. Click Finish (if the nozzle pattern is perfect) OR
10.Click Clean (if the nozzle pattern breaks at certain places)
The following is the sample of good nozzle pattern and a bad nozzle pattern:
Good nozzle pattern:
Bad nozzle pattern (Head Cleaning needed):
Head Cleaning
Head cleaning is required when the nozzle pattern is not perfect. Usually, this action is needed when you have printed a lot or you have taken out the cartridge for refilling or for other purposes. Here's how to perform a head cleaning:
1. Click Start
7. Click Head Cleaning
8. Click Start
9. Click Print Nozzle Patterns (to check the ink flow after cleaning)
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Jun 27, 2009 | Epson Office Equipment & Supplies
Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Mar 17, 2009 | Office Equipment & Supplies
My Canon PIXMA MP760 printer had been printing a horizontal stripe of a lighter cyan where ever that colour occurred. Today during printing it displayed an error. Unfortunately I didn't catch the number. I...
Maybe an obvious answer, but have you cleaned the print heads several times? You can also remove the cartridges, remove the entire print head and clean it with rubbing alcohol and a q-tip.
Mar 28, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Ip4500 printouts have lines through them
I experienced a similar problem when I purchased generic ink off eBay. I did more deep cleans than I can count on my hand, but it did not help. I did the water soaking treatment until there was no more ink coming out of the printhead, but that only made things a *little* better. I finally figured the ink cartridges were bad, so I replaced them. But my new ink did the same thing. So I did the water soaking treatment again. But this time, I forced air through the printhead and actually saw some of the "ink jets" that weren't blowing bubbles out before (when I would blow) begin to blow bubbles. Test results later proved that some of the ink jets were seriously blocked and blowing helped to free them. I do not believe all the jets are free because I still have faded print results, but my results are definitely better! Hope this helps.
Feb 23, 2008 | Canon iP4500 Photo Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus CX9400 Photo Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
