Question about Samsung UN65EH6000F 65" Class 64.5" Diag. 6000 Series LED TV, [...]
HALF OF SCREEN BLACKS OUT
RIGHT SIDE OF SCREEN BLACKS OUT
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
Left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
Dec 21, 2011 | Computers & Internet
Dell d600 blacks out the toolbars
try to point your cursor on the lower side of your screen . Then the toolbar will automatically appear. Right click your mouse and click lock toolbar so that it will not hide.
Oct 15, 2011 | Dell Latitude D600 Notebook
I can only open lid half way and then screen blacks out
Most like ly the cables for the monitor are getting hung up on the hinges, when the lid opens, the hinges are pulling either the main video cable loose from the motherboard on the left side, or the inverter wiring is getting pulled free from the right side. Below is the service manual that will show you how to disassemble the laptop down to the point where you can inspect, reseat and free the hung up cables...or if some of the cables have been rubbed through, tape them up with electrical tape, heat shrink tubing or replace the cables with new ones.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00374392/c00374392.pdf
Nov 11, 2009 | HP Compaq nx9030 Notebook
Gateway W323-UI1 Resolution
Try to upgrade the display driver from gateway.com
Jul 21, 2009 | Computers & Internet
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Top half of screen blacks out
Today, after speaking to the Sansui Manufacturer representative from Japan. He stated that all you need to do is to turn off the closed caption from the TV remote and not the DVR remote. Black screen can occur at the top half or the bottom half of the screen depending on how it was originally setup during installation. Try this and hopefully this fixes the problem.
Oct 06, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Half of screen blacks out
sounds like power supply caps or caps in the dm board
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Mar 22, 2007 | Mitsubishi WD62628 62" Projection HDTV
Samsung UN65EH6000F 65" Class 64.5" Diag. 6000 Series LED TV, [...] Logo
70 people viewed this question
Top Samsung Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Furniture Expert? Answer questions, earn points and help others
