Question about 1997 Ford E-350 Econoline Club Wagon Instrument Cluster Bulb
No running or dash lights on 97 e350 ford van.replace switch and fuse..fuse blows out after a minute and when you turn lights on engine idle decreases
Fuse blows after running a minute..20amp
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 19 Answers
Most likely a short in the front fender parking lights (look for a rubbing wiring harness) or in the tail lights (damaged wiring harness along frame), if the vehicle is in the north, this is more frequent as ice and snow and mud mess up wiring especially heavy salted areas.
Posted on Jun 22, 2014
I have 97 Ford e350 van last weekdashlightsstopped working changed fuses checked light switch has power no dash lights though and high beam indicater now is on when highs off and nothing when high on
You need to check the blue wire w/red trace at the light switch. Also at the dimmer. Those vechs. Had history of the dimmer having issues. If thats where the problem is it can be bypAssed.
Jan 22, 2015 | Ford Cars & Trucks
2008 ford E350 van tail lights won't turn off. It's definitely not the brake lights.
may have a defective headlight switch or a bad relay for rear lights..
Feb 10, 2013 | Cars & Trucks
84 Ford E350 van instrument lights wont work trrough switch
Could be a fuse, or the dimmer switch for the dash lights.
Oct 08, 2012 | 1984 Ford Econoline
I have a 1996 ford 350 van it has a 5.8 engine in it, My problem is when I start it ,It fires right up after a few cranks but if its in park it will idle high and then stall out or if it been running for a...
Take it to AutoZone for a free diagnostic scan. Your local Ford dealer will charge you $100+ for the same scan.
It sounds like the idle control valve and/or the mass air flow sensor. The scan will accurately pinpoint the problem.
Jun 01, 2012 | 2002 Ford E350
My co worker tried to replace a few fuses in the fuse box now the highbeams don't work in our ford e350 van we dont have the owners manual to locate the fuse and was wondering if anyone knows the location...
SOUND LIKE HEAD LIGHT RELAY BAD.LOOK UNDER THE DRIVER SIDE DASH BELOW THE STEERING COLUMN FOR FUSES AND RELAY.YOU HAVE FUSE AND RELAYS UNDER THE HOOD IN THE ENGINE COMPARTMENT ALSO AROUND FENDER AREA.
May 13, 2010 | Ford E-350 Super Duty Cars & Trucks
Hi, My blower on my E350 1994 Ford is not working anymore... Where is it? Perhaps I can replace it myself. HELP !!!
i have a 2000 Ford E350 1 ton Van the heat works in front but blows cold air in rear. Would the problem be a blower heater switch and where is it? I hope I don't have to take off the whole dash.
Jan 28, 2010 | 2002 Ford E350
Air Conditioner Problems
Check for a vacuum leak. The vacuum cannister under the evap. case will crack and cause a leak. I just install a new vacuum cannister,check valve and hose going to inside of van.
May 28, 2009 | 2002 Ford E350
1986 RV blows instrument panel fuse when switch pulled
The headlight switch has a rheostat built into it to dim your dash lights, it may have shorted out. As soon as you turn on the switch this rheostat comes into play and is probably whats blowing the fuse. I think if you replace the headlight switch, it will solve your problems.
May 28, 2009 | 1986 Ford Econoline
2007 ford e350 van, reverse lights wont work
On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
Apr 10, 2009 | 2007 Ford E-150 XLT Wagon
Dash lights and lights on warning noise gone
IT SOUNDS TO ME AS IF IT COULD BE THE ACTUAL STALK, IT IS VERY COMMON ON THESE VANS
Feb 04, 2009 | 1998 Ford Escort
1997 Ford E-350 Econoline Club Wagon Instrument Cluster Bulb Logo
87 people viewed this question
Top GE Vehicle Parts & Accessories Experts
ray012965
ray gallant
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
