Question about Galaxy Radios DX55HP 10 Meter Radio
Galaxy DX 55HP stopped transmitting, but will receive. When the mic is keyed the power meter goes past max and wont transmit. Tried different mics and no difference
Worked good for a few months then started doing this
    Novelist:
  • 500 Answers
Connect to a meter. if there is rf power on a watt meter at full wattage. then the am regulator transistor is bad. less than $5 part.
Posted on Apr 01, 2014
  • 39 Answers
SOURCE: Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
Posted on Apr 04, 2009
  • 181 Answers
SOURCE: Galaxy 949 Receive problem
this sounds as the osolator has moved of freq. to check this you need to put it on a scope
Posted on May 22, 2009
kb8dns
  • 494 Answers
SOURCE: I KEY MIC AND SOMETIMES WON'T TRANSMIT. TAP ON
Cold solder joints are a known bugaboo with these radios......
Posted on Feb 13, 2010
  • 100 Answers
SOURCE: My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
Posted on May 01, 2010
steve132003
  • 98 Answers
SOURCE: I have a Galaxy DX 55v cb radio...The problem I am
sounds like somebody has tampered inside it , knocking out alignments. There is a resistor and very small transistor near back that controls transmit+receive. I don't know which number resistor it is on your model. I know where it is on Uniden/Cobra models(recommend Cobra 25ltd) Take to Cb shop or service repair place. They may help you. Just buy you a Cobra for cheaper and go with it.
Posted on May 01, 2011
Microphone not working
I think it is safe to say 90% of radio problems are microphone. You get a cheap one when you by just about any radio. I believe you are seeing the meter move but not getting audio from your talkback. No matter remove the mic jack plug from radio. For you particular radio looking at the end of the jack notice the small raised numbers. These female connectors no matter the mic type wired for this radio model has the following wires connected or in your case disconnected. 1-(Ground) 2- (Audio) 3-(Transmit) and 4- (Receive).
A RK56 mic would be my suggestion Astatic 636L the second choice a little cheaper but audio it not a crisp.
Don't waste your money a repairing the mic or buying a diesel or road pro or even a cdl mic like a cdl 56 or that Skythumper they are RoadKing 56 wannabees. Sorry about the rant my point is RK56 is Quality.
Apr 12, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
Galaxy DX 98VHP meter stopped moving . There is no swr reading, nothing. Even with a seperatye meter atached or a dummy load, the meter on the galxy is not working. Did I lose all power?
You appear to be aware of you antenna system with the separate meter attached so the tells me you dont punish a radio with an high swr. I am just guessing red wire/solder in mic cord at plug given that it is a side mic mic jack.
Stock mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Jul 02, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I have a Galaxy DX 55v cb radio...The problem I am having is that when I key the mic the radio does key up but will not modulate.I have tried several different mic's...I also have trouble receiving but if...
May 01, 2011 | Galaxy Radios DX-55V Base CB Radio
My radio shows power but its not transmitting out and shows only5 watts on a meter
Don't rely on that meter. use a good Known external meter to check.. make sure your mode switch is on am... not any other mode. also try a different mic. New mics start --RK56's$38.99/Stock mics$6.99...
Mar 07, 2011 | Galaxy Radios DX-95T Base CB Radio
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Feb 04, 2010 | Galaxy Radios DX-66V Base CB Radio
Radio stuck in transmit meter needle is slammed all the way to the right as soon as you turn unit on
Have you recently changed mics ? if so it is wired wrong, if not I would check for a shorted wire in the mic connector or the mic itself.
May 25, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Apr 01, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Galaxy Radios DX55HP 10 Meter Radio Logo
121 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
