Question about Honeywell TH5220D1003 FocusPRO 5000 Digital Non-Programmable Thermostat, Dual S
FocusPro TH5000 will not cool
My system says it's 72 inside. I have the system set to 'Cool' and 68. Only heat comes out, and after 30 mins, the temperature was at 78.
  • Honeywell Master
  • 1,253 Answers
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Posted on Mar 30, 2014
  • 182 Answers
SOURCE: honeywell th4000 thermostat - fan
That problem is seldom the thermostat.check all fuses and breakers....if they're ok,its prolly an internal problem to the furnace.
Posted on Aug 24, 2008
koolbreezes
  • 540 Answers
SOURCE: I don't know how to
Remove the front cover and check your wiring. r-red=power y-yellow=cool w-white=heat g-green=fan.... r-should be hooked up to r-h and a jumper wire-to rc...!
Posted on Sep 05, 2008
heatman101
  • 43501 Answers
SOURCE: I am trying to lower
Many t-stats will not let you go within less than 2 degrees of the heat set point....
Lower the heating set point and then you will be able to lower the cooling setpoint..
heatman101
Posted on May 10, 2011
  • 119 Answers
SOURCE: I had a Honeywell Thermostat
Is this a new hvac system? A new furnace can work differently than your old one. Does it shut off after a minute or two or continue to run? If it continues to run then call that professional back and let him fix it. If it shuts down after a minute or two then it is a feature of the new thermostat to squeeze all of the cool it can from the a/c coil and ductwork.Some of them have settings that you can adjust for blower delay on and off, read the manual that came with the t-stat and see if it does.
Posted on Jun 17, 2011
  • 125 Answers
SOURCE: My A/C is operating outside
With such limited information the following is the most likely problem.
1. The fan outside is running but the compressor is not.
2. The inside air handler blower fan is not working.
3. The system is froze up and not allowing any cold air to come out of the vents.
Hope this helps
Posted on Sep 20, 2011
My thermostate will not shut off when the room
Sounds like a bad tstat
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 21, 2017 | Heating & Cooling
The thermostat is set to heat at a temp of 68 degrees. However,the thermometers temp read 71 and the blower was running and passing cool air. I tried setting the thermometers temp to 72. The furnace...
The burners are not igniting and the timer turned on the blower thinking the burners were already lit by then. You have a burner/ignition problem. Either the ignighter or themocouple is bad
Dec 31, 2017 | Goodman GMS90703BXA Heater
I have a Ruud 2 ton split system and the system will not cool. The compressor and fan on the outside unit works and the fan blower on the air handler works too. The temp on the lines coming into the...
The small line coming in from the outside unit should be warm to hot and the larger line should be cool and sweating with water forming on it. I am taking for granted that the unit was working if so it sounds as if the unit is low on freon. your inside coil should be sweating a lot from top to bottom if it is only cool or sweating on the bottom but less to nothing up top you are low on freon. When very low the unit will stop working just like a broken valve in the compressor. If it is just a little low it will not cool properly and at night it might even freeze the inside coil up.
Aug 08, 2010 | Ruud Handle Air Conditioner
Air conditioner is blowing hot air, it was installed 1995 , the top switch option is CONT FAN AUTO and bottom switch is HEAT OFF COOL and on the right is a dial from 10-30
First of all, what do you mean by hot air? DO YOU REALLY MEAN ROOM TEMERATURE AIR THAT JUST DOES NOT FEEL COLD? If this is a heat pump system, we need to look at it differently than if it is a gas or oil fired heater. Next, the thermostat control that says "cont.fan auto"----- this actually means FAN switch to be in AUTOMATIC RUN or CONTINUOUS RUN mode. Leave it in auto mode and forget that it is there; this little switch confuses a lot of people. The dial that says 10-30 is centegrade temperature that translates to 50-87 degrees farenheit. In order to get air conditioned (cold) air, you must have thermostat fan switch on auto, the heat/off/cool switch on cool, and the 10-30 dial on 20 or 21 (68-70 f.) assuming the room temp is at least 72 degrees f. or higher. If you still do not get cold air, then there is a problem with the cooling circulation system which can be tripped circuit breaker to outside compressor unit, loss of freon refrigerant, bad control such as relay or reversing valve in outside unit, stuck heat sequencers or heat element relay that are giving you heat at the same time giving cold if it is a heatpump system. You will need a skilled service person to determine these problems. Goodluck, Macgivor
Nov 09, 2009 | Cell Phones
Kids reset temperature and now it won't let me set cool to below 70F
hold the button on left an the up button in for five seconds this will enter program mode hit next until 70 comes on and use up dn arrows to set temp info on this stat is on their web site sorry dont have book with me
May 04, 2009 | Heating & Cooling
Honeywell FocusPRO TH6110D auto-changeover unavailable
Do you still have your setup manual go through the setup functions
Nov 25, 2008 | Heating & Cooling
Honeywell TH5220D1003 FocusPRO 5000 Digital Non-Programmable Thermostat, Dual S Logo
454 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
