Question about Dryers
Dryer drum turns but not as easily as before is there a trick to putting it back in and putting the door on
Frigidaire Affinity Dryer front loader
  • 30 Answers
Around the opening of the dryer drum is a felt lined lip (other materials may be used too). This can become clogged with hair and lint. In extreme cases things can get wedged in there (shoelaces, for example).
You could remove the access panels and examine this if you have the tools.
If that's not the problem, you may be looking at a bad drive belt. They do tend to wear out. This can be checked while the access panels are off too.
If neither of these is the case, you may need to bring in a technician to do some deeper tests.
Posted on May 20, 2014
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Have a affinity front load dryer that comes on runs five min then shuts off and all three lights by the start button come on and flash wont heat up
Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Aug 21, 2014 | Frigidaire Affinity FASE7073NW 27"...
My frigidaire affinity front load gas dryer has a banging noise when it runs
you;ll have to examine it closely with a good flashlight to see if u can detect any gaps in drum to front cover (front and back), seam should be even all the way around if not it's gonna be out of balance and hit at points in its rotation , ive seen every thing from baby socks to necklaces get in there and mess it up
Jun 01, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My Frigidaire Affinity dryer keeps wrecking my clothes by breaking straps
In any front load machine, whether washer or dryer, the manufacturer will suggest to have the items with buttons or straps, or small items, put into a mesh bag. Now you can have a professional check to see if you have too much of a gap between the drum and the door itself.
Jul 27, 2012 | Frigidaire Dryers
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
There is a plastic oval piece that fits between the inside of dryer door and outer drum. This piece broke apart. Is this the cause of the noise when dryer is on? Close can easily get caught between frame...
Most frigidaire dryers have front felt seals with nylon slides on top that the front of the drum rides on. Without M# can't be sure if yours is like this.
Dec 28, 2010 | Frigidaire Electric Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Dryer not heating frigidaire affinity front loader
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fgssggs
Feb 22, 2010 | Frigidaire Affinity AEQ6000WH Dryer
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How do I use the dryer rack in the Frigidaire Infinity gas dryer. I can insert it but what do I do to keep the drum from rotating and tossing the rack aroung?
Do you have a lint filter slot inside of your dryer or on the top? Our rack in ours mounts into the lint filter slot and the drum turns around it and does not turn the rack. If you have a lift filter that is on top of the unit the rack may mount into the back panel allowing the drum to turn around it.
Mar 03, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
Top Dryers Experts
