Question about Jensen Awm910 Rv Wall Mount Cd Player Am/fm Radio
Tuning Cannot change from am to fm
How Ido tune it l have no manual.Can you please help.many thanks
Radio With Manual Tuning - Alibaba
www.alibaba.com > Automobiles & Motorcycles > radio > radio with
Radio With Manual Tuning, Buy Various High Quality Radio With Manual TuningProducts from Global Radio With Manual Tuning Suppliers and Radio With ...
Help Guide ' Tuning in an FM radio station manually ... - Sony
https://www.sony.co.uk/.../emanual/.../TP0000016777....
Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
Tuner (radio) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Tuner_(radio)
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
[PDF]Tuning into a Radio Station - Onkyo
Dec 16, 2015 | Audio Players & Recorders
Change fm TO AM (MW)
What is the car year and model there? Sometimes just need "push" volume or tuning button.
Aug 20, 2012 | Cars & Trucks
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
How do you access the fm radio on a Samsung GT-C3300K please. The user manual only mentions the mp3 player. Thank you.
To listen to the FM radio
1. In Menu mode, select FM radio.
2. Select to start the FM radio.
3. Select Yes to start automatic tuning.
The radio scans and saves available stations
automatically.
The first time you turn on the FM radio, you will be
prompted to start automatic tuning.
4. Control the FM radio using the following icons
and keys:
You can find the User Manual that show the FM Radio in this link. Look on Page 25 for the Radio Instructions
Apr 21, 2011 | Samsung Cell Phones
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
I need to know how to change the Preset tuning on a Sony ICF-M350V AM/FM/TV/Weather radio.
Try tuning to the station you want and then hold down the present button you would like programmed for ten seconds... if not then there's always the manual.
May 15, 2009 | Sony Audio Players & Recorders
Frequency increases/decreases in steps of 0.2 kHz
Hi again, Seems you posted twice. A copy of my reply to your other post.... Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sep 13, 2007 | Makita BMR100 Radio
JVC KD-G300
Here is a link to the manual: http://books.jvcservice.com/download/718134980/32506.pdf There does not appear to be a way to set tuning to european standards. Is there a particular reason you want to be able to tune those frequencies?
Mar 12, 2007 | JVC Sirius KD-G300 CD Player
Jensen Awm910 Rv Wall Mount Cd Player Am/fm Radio Logo
37 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
