Question about Yamaha Main Switch Steering Lock
How do I install a main switch in a yamaha c3 scooter?
How do I remove the old one and install the new one?
4 Suggested Answers
  • 850 Answers
SOURCE: my 2006 yamaha 50 bws scooter isn't charging. Its
alternator needs chcking
Posted on Jul 26, 2009
  • 1129 Answers
SOURCE: FOR Yamaha XF50 model Yamaha c3 scooter stolen ignition wires cut
Just pick up some wire connector unions with some shrink wrap.,Identify first the identical matching wire colors (each wire will have a color, example: red with a white strip connects to the other red with white strip etc.) do this to all the wires being sure to slide a length of shrink tube up over one side of the wire before crimping the connector with the two ajoining wires together then slide the tube over the wire crimp connector and use a lighter or heat gun to heat the rubber shrink tube to seal the connector. Do this to all the cut wires one at a time until all are joined together withe union crimping connector method. Be sure you positively identify the color of the wire and its backround stripe color along with the other identical wire that it needs to connect to, you don't want to hook the wires up wrong it could burn something out be caareful and positive the color patterns on the wires to be unioned are identical if you do you will be alright in this job.
Posted on Sep 22, 2009
5keepers541
  • 3497 Answers
SOURCE: how to install HID headlights on a 2007 50 cc
I don't think the electrical system will handle it??
Posted on Jul 01, 2014
Engine light stays on low idle 07 Yamaha c3
Hi, Edward for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2007 Yamaha C3 scooter
2007 Yamaha C3 need help with troubleshooting scooters
http://www.49ccscoot.com/manuals/Yamaha_C3_Service_Manual.pdf
OEM parts for Yamaha
Yamaha XF50E Owner Manual
Nov 06, 2016 | 2007 Yamaha C3
Anybody know what the fuel pressure should be on a 2007 Yamaha c3 scooter
Hi Loren, I am sorry you can't find the first and best tool you ever bought for your Yamaha C3 but despair not for a mere $6.50 you can download another one. For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Yamaha Motorcycle Service Repair Workshop Manuals
Sep 21, 2015 | Yamaha Motorcycles
How to install HID headlights on a 2007 50 cc Yamaha c3 scooter
Jun 21, 2014 | Yamaha Motorcycles
Derestrict yamaha 125 majesty scooter
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XQ125 Derestriction On Two Wheels Forum
How to derestrict Yamaha C3 scooter 1 of 5
Yamaha XQ125 Service Manual
YAMAHA MAJESTY YP125E Owner Manual
Mar 06, 2012 | 2008 Yamaha Majesty 125
Wiring dia. yamaha c3 scooter
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Yamaha C3 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha XF50W Service Manual
Yamaha XC50Z Owner Manual
Jan 13, 2012 | 2007 Yamaha C3
What type of coolant mix is needed for an 06' 50cc Vino? It has been sitting and is not starting. The coolant is low. Could that be the problem. The battery is new and I just changed the oil. The...
Hi, Pharismj and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
2006 08 Yamaha Vino 125cc Won start Seat Latch Scooter Doc Forum
Scooter Troubleshooting Scooter won start All about Scooters
Yamaha XC50V Service Manual
Yamaha XC50W Owner Manual
Aug 11, 2011 | 2006 Yamaha Vino Classic
Where can I get a side stand for a 2009 yamaha c3 scooter
Hi, Trcm2525 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
2002 2011 BWS ZUMA YW50 Bolt On Lateral Side Stand CHROME
Yamaha C3 Parts
Jun 14, 2011 | 2011 Yamaha C3
How to shut off 2008 yamaha c3 scooter engine trouble warning light
Hi, 67impala for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.provoscooter.com/forum/archive/index.php/t-18597.html
Mar 26, 2011 | Yamaha Motorcycles
For a yamaha neo's how would you open the seat
Seat--- To open the seat:--- 1. Place the scooter on the centerstand.-- 2. Insert the key into the main--- switch, and then turn it counterclockwise to “OPEN”.--- NOTE:
Do not push inward when turning the
key.
3. Fold the seat up.
To close the seat
1. Fold the seat down, and then
push it down to lock it in place.
2. Remove the key from the main
switch if the scooter will be left
unattended.
NOTE:
Make sure that the seat is properly
secured before riding.-----------------
This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | 1972 Yamaha XS2
Yamaha Main Switch Steering Lock Logo
19 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
